[Geomoose-users] Reprojection in PostGIS
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 26 06:43:29 PST 2013
Carlo,
No, you can store your data in PostGIS in one SRS (say lat,lon WGS84)
and display it in another (like Spherical Mercator). You can choose
where to do the re-projection:
1. Mapserver, using PROJECTION objects in map file
2. PostGIS using Views
However, if you want to use TinyOWS (instead of GeoServer) as a WFS-T
server to allow feature editing with GeoMoose 2.6, you must store the
data in the same spatial reference system as your display system.
Best Regards,
Brent Fraser
On 2/26/2013 12:08 AM, Carlo Pelliconi wrote:
> About reprojection in postgis: I've used it in a service with
> Mapserver 5.6 (+PHPMapscript+Postgresql 8.4+Postgis 1.5 but without
> framework), before upgrading to Mapserver 6 and start using GeoMOOSE:
> is this functionality lost with GeoMOOSE? Have I to store in postgis
> compulsory with the same projection of the map project?
> Thank you
> Carlo Pelliconi
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
