[Geomoose-users] coordinates showed in footer section
James Klassen
klassen.js at gmail.com
Fri Jan 11 07:58:41 PST 2013
The coordinates display in the same projection as the map is drawn in.
(Although this wouldn't necessarily have to be the case, but I don't
believe anyone has requested otherwise yet.)
Given that, it sounds like you may have skipped Step 4 (Updating
<configuration> in the mapbook).
Note: if you don't display in 3857/900913 you cannot use the common
commercial tile sources for basemaps.
On Fri, Jan 11, 2013 at 4:43 AM, Alejandro Garcia <alegarmen at gmail.com>wrote:
> Hello to all,
> I'm starting to prepare a map web viewer based on geomoose 2.6. All my
> data are in EPSG:32628, that is, UTM28N and WGS84. I followed the
> instruccions I found here (http://www.geomoose.org/docs/projections.html),
> but it doesn't work, I can see maps but not in the correct position by far.
> The aplication seems work always in EPSG:3857. I've seen even in the live
> demo (http://www.geomoose.org/demo/geomoose.html) coordinates showed are
> under EPSG:3857 specifications instead do it in EPSG:26915.
> As you can imagine, show the coordinates in our reference system is very
> important.
> What I'm doing wrong? any help?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130111/948422a0/attachment.html>
More information about the Geomoose-users
