[Geomoose-users] Unsupported output format (image/png;bits=8)
Robert R. Raiz
raizrobert at gmail.com
Wed Jul 24 06:37:24 PDT 2013
I just tried it out. Both:
WEB
METADATA
'ows_title' 'Parcel Maps'
'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:4269 EPSG:2277'
'ows_enable_request' '*'
'ows_onlineresource' 'http://www.geomoose.org'
END
END
OUTPUTFORMAT
NAME "png8"
DRIVER AGG/PNG8
MIMETYPE "image/png; mode=8bit"
IMAGEMODE RGB
EXTENSION "png"
END
And:
OUTPUTFORMAT
NAME "png32"
DRIVER AGG/PNG
MIMETYPE "image/png; mode=32bit"
IMAGEMODE RGBA
EXTENSION "png"
END
Both return the same error. I think the syntax is quite ok, I do not see
what could be wrong as there are a few simple lines.
If I put DRIVER AGG/PNG32 is returns another error: loadOutputFormat():
General error message. OUTPUTFORMAT clause references driver AGG/PNG32, but
this driver isn't configured.
On Wed, Jul 24, 2013 at 4:31 PM, Brent Fraser <bfraser at geoanalytic.com>wrote:
> It might be the IMAGEMODE RGBA (this implies 32 bit output) combined
> with the MIMITYPE "image/png; mode=8bit" (which defines 8 bit output) .
> But the fact that error message states "bits=8", which is not the correct
> syntax for the MIMETYPE, suggests you need to dobule check you are using
> the mapfile with the correct syntax (mode=8bit).
> Best Regards,
> Brent Fraser
> On 7/24/2013 7:03 AM, Robert R. Raiz wrote:
> I read all day about the outputs and it seems that it should display
> everything ok even if I do not specify the outputformat.
> Everything I modify returns *"msWMSLoadGetMapParams(): Image handling
> error. Unsupported output format (image/png;bits=8)"*
> Is it possible ?! to come from the following part:
> WEB
> METADATA
> END
> END
> I did not use this before and I wonder if the MIMTYPE is somehow returned
> all the time as png 8 bit. If I remove this part, again, I get an error.
*Raiz Roland Robert*
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130724/479eb8a5/attachment.html>
More information about the Geomoose-users
