[Geomoose-users] Unsupported output format (image/png;bits=8)
Brent Fraser bfraser at geoanalytic.com
Wed Jul 24 06:53:42 PDT 2013
Here's the definition I appear to be using:
     IMAGETYPE AGG_PNG
     OUTPUTFORMAT
         NAME  'AGG_PNG'
         DRIVER AGG/PNG
#        MIMETYPE "image/png;mode=24bit"
         MIMETYPE "image/png"
         IMAGEMODE RGBA    # renders IMAGECOLOR transparent
         EXTENSION "png"
         FORMATOPTION "INTERLACE=false"
         FORMATOPTION "TRANSPARENT=ON"
         TRANSPARENT ON
         FORMATOPTION "QUANTIZE_FORCE=ON"
         FORMATOPTION "QUANTIZE_DITHER=off"
         FORMATOPTION "QUANTIZE_COLORS=256"
     END
Which version of Mapserver are you using?
Best Regards,
Brent Fraser
On 7/24/2013 7:37 AM, Robert R. Raiz wrote:
> I just tried it out. Both:
> WEB
> METADATA
> 'ows_title' 'Parcel Maps'
> 'ows_srs' 'EPSG:26915 EPSG:4326 EPSG:900913 EPSG:4269 EPSG:2277'
> 'ows_enable_request' '*'
> 'ows_onlineresource' 'http://www.geomoose.org'
> END
> END
> OUTPUTFORMAT
>  NAME "png8"
>  DRIVER AGG/PNG8
>  MIMETYPE "image/png; mode=8bit"
>  IMAGEMODE RGB
>  EXTENSION "png"
> END
> And:
>         OUTPUTFORMAT
>  NAME "png32"
>  DRIVER AGG/PNG
>  MIMETYPE "image/png; mode=32bit"
>  IMAGEMODE RGBA
>  EXTENSION "png"
> END
> Both return the same error. I think the syntax is quite ok, I do not
> see what could be wrong as there are a few simple lines.
> If I put DRIVER AGG/PNG32 is returns another
> error: loadOutputFormat(): General error message. OUTPUTFORMAT clause
> references driver AGG/PNG32, but this driver isn't configured.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20130724/3ad3e888/attachment.html>
More information about the Geomoose-users mailing list
