[Geomoose-users] My Data Projected in wrong area
INDRA BAYU
cucuberlian at gmail.com
Fri Mar 29 08:54:14 PDT 2013
How can i do it Jim?
I have change my map file
MAP
EXTENT 681064.622758 9296398.489077 696909.822267 9311182.143822
PROJECTION
'init=epsg:3857'
END
LAYER
PROJECTION
'init=epsg: 32748
END
END
END
It dosn’t work. My map is not showing.
I think i have to changed my EXTENT, but i dont know how it work with epsg:3857
Is there anyone know how to fix this proclem?
> 2013/3/28, Jim Klassen <klassen.js at gmail.com>:
>> The Google (and other generally available tiled datasets like OSM, Bing,
>> Mapquest) are only available in the default EPSG:3857 projection, scales,
>> and max extent. This is because all of those parameters need to match so
>> GeoMoose (actually OpenLayers) can calculate the same coordinate to tile
>> lookup as was used to create the tileset.
>> ArcGIS Rest is likely smarter (and lets the client specify a coordinate
>> system to the server). I am not very familiar with using ArcGIS Rest.
>> If you want to use the Google layers, then you should leave GeoMoose in
>> 3857
>> and then use Mapserver to project your data from 32748 to 3857 (Set the
>> data
>> projection in the layer and the "3857" projection at the map level).
>> On Mar 28, 2013, at 10:49 AM, INDRA BAYU wrote:
>>> i have fixed EPSG:32748 in settings.ini.
>>> In geomoose when i use "ArcGIS 9.3 Rest Example" for Background, my
>>> data projected in right area. but if i use google or yahoo or osm for
>>> Background, my data projected in wrong area. how i fix it?
>>> i attach my mapfile and my shp. might be you want to check
>>> thanks
>>> 2013/3/28, James Klassen <klassen.js at gmail.com>:
>>>> Check with another WMS client (such as QGIS) if MapServer is projecting
>>>> your data correctly. What does your MapServer LAYER look like?
>>>> For most WMS clients to work OWS_ONLINERESOURCE should point to your
>>>> mapfile not the geomoose website.
>>>> It looks like you may have a space in EPSG:32748 in settings.INI, but
>>>> that
>>>> wouldn't cause your problem.
>>>> You don't need to edit config.js. The values in the map book will
>>>> override
>>>> those in config.js. (Also I think config.js gets compiled in during
>>>> the
>>>> build so changes there would only take effect if you rebuilt GeoMoose
>>>> or
>>>> were using GeoMoose_Dev.html.)
>>>> On Mar 28, 2013 5:36 AM, "INDRA BAYU" <cucuberlian at gmail.com> wrote:
>>>>> I am new to GeoMoose. I use GeoMoose 2.6.1. I have added my data and
>>>>> have it projecting. The data is all WGS_1984_UTM_Zone_48S. I needed
>>>>> EPSG: 32748 fo this data. I added the new EPSG as per the GeoMoose
>>>>> instructions on http://www.geomoose.org/docs/projections.html.
>>>>> this is my configuration:
>>>>> ====EPSG32748.js====
>>>>> Proj4js.defs["EPSG:32748"] = "+proj=utm +zone=48 +south +ellps=WGS84
>>>>> +datum=WGS84 +units=m +no_defs";
>>>>> =====geomoose.html======
>>>>> <script type="text/javascript"
>>>>> src="projections/EPSG32748.js"></script>
>>>>> src="projections/EPSG26915.js"></script>
>>>>> <script type="text/javascript" src="projections/EPSG3857.js"></script>
>>>>> =====myshapefile.shp=========
>>>>> WEB
>>>>> METADATA
>>>>> 'ows_title' 'Parcel Maps'
>>>>> 'ows_srs' 'EPSG:32748 EPSG:26915 EPSG:4326 EPSG:900913
>>>>> EPSG:3857'
>>>>> 'ows_enable_request' '*'
>>>>> 'ows_onlineresource' 'http://www.geomoose.org'
>>>>> END
>>>>> END
>>>>> PROJECTION
>>>>> 'init=epsg:32748'
>>>>> END
>>>>> =====mapbook.xml=======
>>>>> <param name="projection">EPSG:32748</param>
>>>>> <param
>>>>> name="max_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
>>>>> <param
>>>>> name="initial_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
>>>>> =====settings.ini====
>>>>> [defaults]
>>>>> ; Location of the default mapbook
>>>>> mapbook=mapbook.xml
>>>>> [map]
>>>>> projection=EPSG: 32748
>>>>> ===config.js====
>>>>> var CONFIGURATION = {
>>>>> 'links_bar_html' : "",
>>>>> 'waiting_html' : 'Loading...',
>>>>> 'mapserver_url' : "",
>>>>> 'control_panel_side' : 'left',
>>>>> 'mapfile_root' : "",
>>>>> 'mapbook' : "php/getmapbook.php",
>>>>> 'fractional_zoom' : false,
>>>>> 'scales' : [1,2,4,8,16,32,64,128,256,500,1000,5000],
>>>>> 'max_extent' :
>>>>> [681064.622758,9296398.489077,696909.822267,9311182.143822],
>>>>> 'initial_extent' :
>>>>> 'projection' : "EPSG:32748",
>>>>> 'ground_units' : 'm',
>>>>> My data is being projected on nowegian sea (my data is in indonesia) .
>>>>> Does anyone know what I am doing wrong?
>>>>> Thanks
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> <geomoose.zip>
More information about the Geomoose-users
