[Geomoose-users] My Data Projected in wrong area
Eli Adam
eadam at co.lincoln.or.us
Fri Mar 29 09:16:28 PDT 2013
On Fri, Mar 29, 2013 at 8:54 AM, INDRA BAYU <cucuberlian at gmail.com> wrote:
> How can i do it Jim?
> I have change my map file
> MAP
> EXTENT 681064.622758 9296398.489077 696909.822267 9311182.143822
> PROJECTION
> 'init=epsg:3857'
> END
> LAYER
> PROJECTION
> 'init=epsg: 32748
> END
> END
> END
> It dosn’t work. My map is not showing.
> I think i have to changed my EXTENT, but i dont know how it work with epsg:3857
> Is there anyone know how to fix this proclem?
You might be able to use
http://www.spatialreference.org/ref/sr-org/epsg3857/ with the red
marker showing the coordinates in the upper right to determine values
that are appropriate for your extent in 3857. Move the map around
until the red marked is where you want.
HTH, Eli
>> 2013/3/28, Jim Klassen <klassen.js at gmail.com>:
>>> The Google (and other generally available tiled datasets like OSM, Bing,
>>> Mapquest) are only available in the default EPSG:3857 projection, scales,
>>> and max extent. This is because all of those parameters need to match so
>>> GeoMoose (actually OpenLayers) can calculate the same coordinate to tile
>>> lookup as was used to create the tileset.
>>> ArcGIS Rest is likely smarter (and lets the client specify a coordinate
>>> system to the server). I am not very familiar with using ArcGIS Rest.
>>> If you want to use the Google layers, then you should leave GeoMoose in
>>> 3857
>>> and then use Mapserver to project your data from 32748 to 3857 (Set the
>>> data
>>> projection in the layer and the "3857" projection at the map level).
>>> On Mar 28, 2013, at 10:49 AM, INDRA BAYU wrote:
>>>> i have fixed EPSG:32748 in settings.ini.
>>>> In geomoose when i use "ArcGIS 9.3 Rest Example" for Background, my
>>>> data projected in right area. but if i use google or yahoo or osm for
>>>> Background, my data projected in wrong area. how i fix it?
>>>> i attach my mapfile and my shp. might be you want to check
>>>> thanks
>>>> 2013/3/28, James Klassen <klassen.js at gmail.com>:
>>>>> Check with another WMS client (such as QGIS) if MapServer is projecting
>>>>> your data correctly. What does your MapServer LAYER look like?
>>>>> For most WMS clients to work OWS_ONLINERESOURCE should point to your
>>>>> mapfile not the geomoose website.
>>>>> It looks like you may have a space in EPSG:32748 in settings.INI, but
>>>>> that
>>>>> wouldn't cause your problem.
>>>>> You don't need to edit config.js. The values in the map book will
>>>>> override
>>>>> those in config.js. (Also I think config.js gets compiled in during
>>>>> the
>>>>> build so changes there would only take effect if you rebuilt GeoMoose
>>>>> or
>>>>> were using GeoMoose_Dev.html.)
>>>>> On Mar 28, 2013 5:36 AM, "INDRA BAYU" <cucuberlian at gmail.com> wrote:
>>>>>> I am new to GeoMoose. I use GeoMoose 2.6.1. I have added my data and
>>>>>> have it projecting. The data is all WGS_1984_UTM_Zone_48S. I needed
>>>>>> EPSG: 32748 fo this data. I added the new EPSG as per the GeoMoose
>>>>>> instructions on http://www.geomoose.org/docs/projections.html.
>>>>>> this is my configuration:
>>>>>> ====EPSG32748.js====
>>>>>> Proj4js.defs["EPSG:32748"] = "+proj=utm +zone=48 +south +ellps=WGS84
>>>>>> +datum=WGS84 +units=m +no_defs";
>>>>>> =====geomoose.html======
>>>>>> <script type="text/javascript"
>>>>>> src="projections/EPSG32748.js"></script>
>>>>>> src="projections/EPSG26915.js"></script>
>>>>>> <script type="text/javascript" src="projections/EPSG3857.js"></script>
>>>>>> =====myshapefile.shp=========
>>>>>> WEB
>>>>>> METADATA
>>>>>> 'ows_title' 'Parcel Maps'
>>>>>> 'ows_srs' 'EPSG:32748 EPSG:26915 EPSG:4326 EPSG:900913
>>>>>> EPSG:3857'
>>>>>> 'ows_enable_request' '*'
>>>>>> 'ows_onlineresource' 'http://www.geomoose.org'
>>>>>> END
>>>>>> END
>>>>>> PROJECTION
>>>>>> 'init=epsg:32748'
>>>>>> END
>>>>>> =====mapbook.xml=======
>>>>>> <param name="projection">EPSG:32748</param>
>>>>>> <param
>>>>>> name="max_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
>>>>>> <param
>>>>>> name="initial_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
>>>>>> =====settings.ini====
>>>>>> [defaults]
>>>>>> ; Location of the default mapbook
>>>>>> mapbook=mapbook.xml
>>>>>> [map]
>>>>>> projection=EPSG: 32748
>>>>>> ===config.js====
>>>>>> var CONFIGURATION = {
>>>>>> 'links_bar_html' : "",
>>>>>> 'waiting_html' : 'Loading...',
>>>>>> 'mapserver_url' : "",
>>>>>> 'control_panel_side' : 'left',
>>>>>> 'mapfile_root' : "",
>>>>>> 'mapbook' : "php/getmapbook.php",
>>>>>> 'fractional_zoom' : false,
>>>>>> 'scales' : [1,2,4,8,16,32,64,128,256,500,1000,5000],
>>>>>> 'max_extent' :
>>>>>> [681064.622758,9296398.489077,696909.822267,9311182.143822],
>>>>>> 'initial_extent' :
>>>>>> 'projection' : "EPSG:32748",
>>>>>> 'ground_units' : 'm',
>>>>>> My data is being projected on nowegian sea (my data is in indonesia) .
>>>>>> Does anyone know what I am doing wrong?
>>>>>> Thanks
>>>>>> _______________________________________________
>>>>>> Geomoose-users mailing list
>>>>>> Geomoose-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> <geomoose.zip>
More information about the Geomoose-users
