[Geomoose-users] My Data Projected in wrong area
Jim Klassen
klassen.js at gmail.com
Fri Mar 29 09:19:14 PDT 2013
You are correct, EXTENT should be in the MAP projection, however that isn't usually the problem because GeoMoose passes in its own extent that overrides the one set in the mapfile.
I presume that is a shortened mapfile to only show the projection parts and the real mapfile is longer.
You can reproject your extent using the cs2cs tool that is part of the proj4 package (which is almost always already installed if you have mapserver).
Assuming you have proj4 and bash (shell) installed
cs2cs +init=epsg:32748 +to +init=epsg:3857 <( echo 681064.622758 9296398.489077 ; echo 696909.822267 9311182.143822 )
11870774.49 -709769.35 0.00
11886665.80 -694745.80 0.00
Alternatively you can type/copy in the coordinates, when you press enter it will respond with the reprojected coordinate.
So:
EXTENT 11870774.49 -709769.35 11886665.80 -694745.80
On Mar 29, 2013, at 10:53 AM, INDRA BAYU wrote:
> How can i do it Jim?
> I have change my map file
> MAP
> EXTENT 681064.622758 9296398.489077 696909.822267 9311182.143822
> PROJECTION
> 'init=epsg:3857'
> END
> LAYER
> PROJECTION
> 'init=epsg: 32748
> END
> END
> END
> It dosn’t work. My map is not showing.
> I think i have to changed my EXTENT, but i dont know how it work with epsg:3857
> Is there anyone know how to fix this proclem?
> 2013/3/28, Jim Klassen <klassen.js at gmail.com>:
>> The Google (and other generally available tiled datasets like OSM, Bing,
>> Mapquest) are only available in the default EPSG:3857 projection, scales,
>> and max extent. This is because all of those parameters need to match so
>> GeoMoose (actually OpenLayers) can calculate the same coordinate to tile
>> lookup as was used to create the tileset.
>> ArcGIS Rest is likely smarter (and lets the client specify a coordinate
>> system to the server). I am not very familiar with using ArcGIS Rest.
>> If you want to use the Google layers, then you should leave GeoMoose in 3857
>> and then use Mapserver to project your data from 32748 to 3857 (Set the data
>> projection in the layer and the "3857" projection at the map level).
>> On Mar 28, 2013, at 10:49 AM, INDRA BAYU wrote:
>>> i have fixed EPSG:32748 in settings.ini.
>>> In geomoose when i use "ArcGIS 9.3 Rest Example" for Background, my
>>> data projected in right area. but if i use google or yahoo or osm for
>>> Background, my data projected in wrong area. how i fix it?
>>> i attach my mapfile and my shp. might be you want to check
>>> thanks
>>> 2013/3/28, James Klassen <klassen.js at gmail.com>:
>>>> Check with another WMS client (such as QGIS) if MapServer is projecting
>>>> your data correctly. What does your MapServer LAYER look like?
>>>> For most WMS clients to work OWS_ONLINERESOURCE should point to your
>>>> mapfile not the geomoose website.
>>>> It looks like you may have a space in EPSG:32748 in settings.INI, but
>>>> that
>>>> wouldn't cause your problem.
>>>> You don't need to edit config.js. The values in the map book will
>>>> override
>>>> those in config.js. (Also I think config.js gets compiled in during the
>>>> build so changes there would only take effect if you rebuilt GeoMoose or
>>>> were using GeoMoose_Dev.html.)
>>>> On Mar 28, 2013 5:36 AM, "INDRA BAYU" <cucuberlian at gmail.com> wrote:
>>>>> I am new to GeoMoose. I use GeoMoose 2.6.1. I have added my data and
>>>>> have it projecting. The data is all WGS_1984_UTM_Zone_48S. I needed
>>>>> EPSG: 32748 fo this data. I added the new EPSG as per the GeoMoose
>>>>> instructions on http://www.geomoose.org/docs/projections.html.
>>>>> this is my configuration:
>>>>> ====EPSG32748.js====
>>>>> Proj4js.defs["EPSG:32748"] = "+proj=utm +zone=48 +south +ellps=WGS84
>>>>> +datum=WGS84 +units=m +no_defs";
>>>>> =====geomoose.html======
>>>>> <script type="text/javascript" src="projections/EPSG32748.js"></script>
>>>>> <script type="text/javascript" src="projections/EPSG26915.js"></script>
>>>>> <script type="text/javascript" src="projections/EPSG3857.js"></script>
>>>>> =====myshapefile.shp=========
>>>>> WEB
>>>>> METADATA
>>>>> 'ows_title' 'Parcel Maps'
>>>>> 'ows_srs' 'EPSG:32748 EPSG:26915 EPSG:4326 EPSG:900913
>>>>> EPSG:3857'
>>>>> 'ows_enable_request' '*'
>>>>> 'ows_onlineresource' 'http://www.geomoose.org'
>>>>> END
>>>>> END
>>>>> PROJECTION
>>>>> 'init=epsg:32748'
>>>>> END
>>>>> =====mapbook.xml=======
>>>>> <param name="projection">EPSG:32748</param>
>>>>> <param
>>>>> name="max_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
>>>>> <param
>>>>> name="initial_extent">681064.622758,9296398.489077,696909.822267,9311182.143822</param>
>>>>> =====settings.ini====
>>>>> [defaults]
>>>>> ; Location of the default mapbook
>>>>> mapbook=mapbook.xml
>>>>> [map]
>>>>> projection=EPSG: 32748
>>>>> ===config.js====
>>>>> var CONFIGURATION = {
>>>>> 'links_bar_html' : "",
>>>>> 'waiting_html' : 'Loading...',
>>>>> 'mapserver_url' : "",
>>>>> 'control_panel_side' : 'left',
>>>>> 'mapfile_root' : "",
>>>>> 'mapbook' : "php/getmapbook.php",
>>>>> 'fractional_zoom' : false,
>>>>> 'scales' : [1,2,4,8,16,32,64,128,256,500,1000,5000],
>>>>> 'max_extent' :
>>>>> [681064.622758,9296398.489077,696909.822267,9311182.143822],
>>>>> 'initial_extent' :
>>>>> 'projection' : "EPSG:32748",
>>>>> 'ground_units' : 'm',
>>>>> My data is being projected on nowegian sea (my data is in indonesia) .
>>>>> Does anyone know what I am doing wrong?
>>>>> Thanks
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> <geomoose.zip>
More information about the Geomoose-users
