[Geomoose-users] Help; is there anybody that knows how to use a DFX or KML in Geomoose?
James Klassen
klassen.js at gmail.com
Thu Nov 14 14:52:30 PST 2013
Read support means support for reading that file type. GDAL is also
included in MS4W so you probably wouldn't need OSGeo4W on the server.
I haven't tried using DXF directly in MapServer. I have used AutoCAD
generated layers both as shp (including text converted to polygons) and as
the DWG plotted to a PNG + world file and then served as a raster via
MapServer.
On Nov 14, 2013 3:58 PM, "Behr Mirfathali" <behr at coastcom.net> wrote:
> Hello,
> I have files I am exporting out of AutoCAD Map for Geomoose. We have so
> many text layers to deal with so it looks like a DWF or a KML/KMZ layer
> would be easier to work with. I did a little research and I found that both
> types can be used.
> http://gdal.org/ogr/ogr_formats.html For KML it says it needs *(read
> support needs libexpat). *I am not sure what is meant by ‘read support’.
> And
> According to this
> http://wiki.ieee-earth.org/Documents/GEOSS_Tutorials/GEOSS_Provider_Tutorials/Web_Feature_Service_Tutorial_for_GEOSS_Providers/Section_4%3A_Provisioning%2F%2FUsing_the_service_or_application/Section_4.3%3A_Detail_Steps_for_Use_Cases/Section_4.3.1%3A_Offering_a_DXF_file_with_mapserver_WFS
> I would have to install OSGeo4W to the server. But what version? Also,
> what version of DXF? 2013? 2010? I would have thought the original
> Mapserver would have at least been able to use the DXF format given its
> history.
> Any thoughts?
> All help is appreciated.
> Thank you
> Behr
> *Behr Mirfathali* | Engineering Technician
> Direct 360.326.5582 | Fax 541.265.8946|
> behr at coastcom.net | www.coastcom.net
> [image: signature]
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/f9ec0c19/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/f9ec0c19/attachment.jpg>
More information about the Geomoose-users
