[Geomoose-users] Help; is there anybody that knows how to use a DFX or KML in Geomoose?
Brent Fraser bfraser at geoanalytic.com
Thu Nov 14 14:43:41 PST 2013
Behr,
   I've used DXF with GeoMoose.    Likely your version of Mapserver has
the capabilities built in.  Try something like I did by setting up a
mapserver mapsource with a map file containing a layer definition like:
   LAYER
     NAME 'Alberta'
     STATUS on
     TYPE LINE
     CONNECTIONTYPE OGR
     CONNECTION 'T:\GeoData\Parcels\Alberta\brooks.dxf' # entities'
     PROJECTION
         'init=epsg:3403'
     END
     STYLEITEM 'AUTO'
     CLASS
        NAME 'Rural DXF'
     END
   END
Typical problems relate to the coordinates stored in the DXF files
(sometimes "local" coordinate systems are used).
Best Regards,
Brent Fraser
On 11/14/2013 2:58 PM, Behr Mirfathali wrote:
> Hello,
> I have files I am exporting out of AutoCAD Map for Geomoose. We have
> so many text layers to deal with so it looks like a DWF or a KML/KMZ
> layer would be easier to work with. I did a little research and I
> found that both types can be used.
> http://gdal.org/ogr/ogr_formats.html  For KML it says it needs *(read
> support needs libexpat). *I am not sure what is meant by 'read support'.
> And
> According to this
> http://wiki.ieee-earth.org/Documents/GEOSS_Tutorials/GEOSS_Provider_Tutorials/Web_Feature_Service_Tutorial_for_GEOSS_Providers/Section_4%3A_Provisioning%2F%2FUsing_the_service_or_application/Section_4.3%3A_Detail_Steps_for_Use_Cases/Section_4.3.1%3A_Offering_a_DXF_file_with_mapserver_WFS
> I would have to install OSGeo4W to the server. But what version? Also,
> what version of DXF? 2013? 2010? I would have thought the original
> Mapserver would have at least been able to use the DXF format given
> its history.
> Any thoughts?
> All help is appreciated.
> Thank you
> Behr
> *Behr Mirfathali* | Engineering Technician
> Direct 360.326.5582 | Fax 541.265.8946|
> behr at coastcom.net | www.coastcom.net <http://www.coastcom.net/>
> signature
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/c7fb8363/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/c7fb8363/attachment-0001.jpe>
More information about the Geomoose-users mailing list
