[Geomoose-users] Help; is there anybody that knows how to use a DFX or KML in Geomoose?
Brent Fraser
bfraser at geoanalytic.com
Thu Nov 14 15:55:22 PST 2013
Nope, just the LAYER part. Have a look at one of the demo .map files
supplied with GeoMoose to see the other parts required (MAP, WEB,
LEGEND,...)
Best Regards,
Brent Fraser
On 11/14/2013 4:25 PM, Behr Mirfathali wrote:
> Hello and thank you.
> Would this be the entire MAP file needed?
> *From:*Brent Fraser [mailto:bfraser at geoanalytic.com]
> *Sent:* Thursday, November 14, 2013 2:44 PM
> *To:* Behr Mirfathali; geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Help; is there anybody that knows how
> Behr,
> I've used DXF with GeoMoose. Likely your version of Mapserver has
> the capabilities built in. Try something like I did by setting up a
> mapserver mapsource with a map file containing a layer definition like:
> LAYER
> NAME 'Alberta'
> STATUS on
> TYPE LINE
> CONNECTIONTYPE OGR
> CONNECTION 'T:\GeoData\Parcels\Alberta\brooks.dxf' # entities'
> PROJECTION
> 'init=epsg:3403'
> END
> STYLEITEM 'AUTO'
> CLASS
> NAME 'Rural DXF'
> END
> END
> Typical problems relate to the coordinates stored in the DXF files
> (sometimes "local" coordinate systems are used).
> Best Regards,
> Brent Fraser
> On 11/14/2013 2:58 PM, Behr Mirfathali wrote:
> Hello,
> I have files I am exporting out of AutoCAD Map for Geomoose. We
> have so many text layers to deal with so it looks like a DWF or a
> KML/KMZ layer would be easier to work with. I did a little
> research and I found that both types can be used.
> http://gdal.org/ogr/ogr_formats.html For KML it says it needs
> *(read support needs libexpat). *I am not sure what is meant by
> 'read support'.
> And
> According to this
> http://wiki.ieee-earth.org/Documents/GEOSS_Tutorials/GEOSS_Provider_Tutorials/Web_Feature_Service_Tutorial_for_GEOSS_Providers/Section_4%3A_Provisioning%2F%2FUsing_the_service_or_application/Section_4.3%3A_Detail_Steps_for_Use_Cases/Section_4.3.1%3A_Offering_a_DXF_file_with_mapserver_WFS
> I would have to install OSGeo4W to the server. But what version?
> Also, what version of DXF? 2013? 2010? I would have thought the
> original Mapserver would have at least been able to use the DXF
> format given its history.
> Any thoughts?
> All help is appreciated.
> Thank you
> Behr
> *Behr Mirfathali* | Engineering Technician
> Direct 360.326.5582 | Fax 541.265.8946|
> behr at coastcom.net <mailto:behr at coastcom.net> | www.coastcom.net
> <http://www.coastcom.net/>
> signature
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/a40e97b3/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131114/a40e97b3/attachment-0001.jpe>
More information about the Geomoose-users
