[Geomoose-users] Edit select type attributes in vector layer.
Dan Little
danlittle at yahoo.com
Tue Nov 19 12:16:32 PST 2013
I suspect the "select" input type is not working properly in the feature editor.
Can you file a ticket on GitHub? https://github.com/geomoose/geomoose/issues/new
On Tue, 11/19/13, Luis Calisto <luis.calisto at hotmail.com> wrote:
Subject: Re: [Geomoose-users] Edit select type attributes in vector layer.
To: "Mark Volz" <markvolz at co.lyon.mn.us>, "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
Date: Tuesday, November 19, 2013, 9:54 AM
I removed the "(%)" and tried
with the following code:
<attribute
name="test" type="select"
default-value="50" label="Opacity:"
> <option
value="0">0</option> <option
value="50">50</option> </attribute>
still i have the same error: "Uncaught
TypeError: Cannot call method 'getElementsByTagName'
of null "
What can it be?
MarkVolz at co.lyon.mn.us
To: luis.calisto at hotmail.com;
Subject: RE: [Geomoose-users] Edit select type attributes in
vector layer.
Date: Tue, 19 Nov 2013 15:35:37 +0000
Luis,
I am NOT the expert
on this, but I would check and see if “(%)” is legal or
not by removing those characters from the label.
Mark Volz,
GISP
GIS
Specialist
geomoose-users-bounces at lists.osgeo.org
[mailto:geomoose-users-bounces at lists.osgeo.org]
On Behalf Of Luis Calisto
Sent: Tuesday, November 19, 2013 9:02 AM
To: geomoose-users at lists.osgeo.org
Subject: [Geomoose-users] Edit select type attributes
in vector layer.
I'm
working with the vector layers and the feature attribute
edit tool, all works great but i can't put working an
attribute that is configured in the mapbook with the type
"select".
In the
demo mapbook example, the vector layer "sketch"
there is a commented line:
<attribute name="opacity"
type="select" default-value="100"
label="Opacity (%):"/>
If i
uncomment this line when i select the "edit
attributes" tool it gives this error in the console:
"Uncaught TypeError: Cannot call method
'getElementsByTagName' of null
I changed
the attribute options in the mapbook demo to:
label="Opacity (%):">
<option
<option
</attribute>
But same
error! Any idea? Is it possible to use the select type
in the vector attributes?
Best
regards
Luís
Calisto
-----Inline Attachment Follows-----
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
