[Geomoose-users] Edit select type attributes in vector layer.
Luis Calisto luis.calisto at hotmail.com
Wed Nov 20 06:42:44 PST 2013
Hi Dan
I just open a ticket on GitHub
https://github.com/geomoose/geomoose/issues/33
> Date: Tue, 19 Nov 2013 12:16:32 -0800
> From: danlittle at yahoo.com
> Subject: Re: [Geomoose-users] Edit select type attributes in vector layer.
> To: markvolz at co.lyon.mn.us; geomoose-users at lists.osgeo.org; luis.calisto at hotmail.com
> I suspect the "select" input type is not working properly in the feature editor.
> Can you file a ticket on GitHub? https://github.com/geomoose/geomoose/issues/new
>  To: "Mark Volz" <markvolz at co.lyon.mn.us>, "geomoose-users at lists.osgeo.org" <geomoose-users at lists.osgeo.org>
>  Date: Tuesday, November 19, 2013, 9:54 AM
>  I removed the "(%)" and tried
>  with the following code:
>  		<attribute
>  name="test" type="select"
>  default-value="50" label="Opacity:"
>  >					<option
>  value="0">0</option>			<option
>  value="50">50</option> 		</attribute>
>  still i have the same error: "Uncaught
>  TypeError: Cannot call method 'getElementsByTagName'
>  of null "
>  What can it be?
>  From:
>  MarkVolz at co.lyon.mn.us
>  To: luis.calisto at hotmail.com;
>  Subject: RE: [Geomoose-users] Edit select type attributes in
>  vector layer.
>  Date: Tue, 19 Nov 2013 15:35:37 +0000
>  Luis,
>  I am NOT the expert
>  on this, but I would check and see if “(%)” is legal or
>  not by removing those characters from the label.
>  Mark Volz,
>  GISP
>  GIS
>  Specialist
>  From:
>  geomoose-users-bounces at lists.osgeo.org
>  [mailto:geomoose-users-bounces at lists.osgeo.org]
>  On Behalf Of Luis Calisto
>  Sent: Tuesday, November 19, 2013 9:02 AM
>  To: geomoose-users at lists.osgeo.org
>  Subject: [Geomoose-users] Edit select type attributes
>  in vector layer.
>  Hi,
>  I'm
>  working with the vector layers and the feature attribute
>  edit tool, all works great but i can't put working an
>  attribute that is configured in the mapbook with the type
>  "select".
>  In the
>  demo mapbook example, the vector layer "sketch"
>  there is a commented line:
>  <attribute name="opacity"
>  type="select" default-value="100"
>  label="Opacity (%):"/>
>  If i
>  uncomment this line when i select the "edit
>  attributes" tool it gives this error in the console:
>  "Uncaught TypeError: Cannot call method
>  'getElementsByTagName' of null
>  I changed
>  the attribute options in the mapbook demo to:
>  label="Opacity (%):">
>  <option
>  <option
>  </attribute>
>  But same
>  error! Any idea? Is it possible to use the select type
>  in the vector attributes?
>  Best
>  regards
>  Luís
>  Calisto
>  -----Inline Attachment Follows-----
>  _______________________________________________
>  Geomoose-users mailing list
>  Geomoose-users at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20131120/e07066f1/attachment.html>
More information about the Geomoose-users mailing list
