[Geomoose-users] Out of the box mapping application for GeoServer
Dan Little
theduckylittle at gmail.com
Fri Apr 25 08:50:44 PDT 2014
Um, Do both? GeoMOOSE can operate pretty well on standard WxS services.
On Fri, Apr 25, 2014 at 9:28 AM, Basques, Bob (CI-StPaul)
<bob.basques at ci.stpaul.mn.us> wrote:
> Mark,
> Hmm, I don’t know what you are after capability wise, but GeoMoose does all
> of what you have listed (Mobile needs some more dressing up, but it does
> work). GeoServer should be usable with GeoMoose as well. GeoMoose is set
> up by default to use WMS services in it’s most recent incarnations, which
> doesn’t preclude it’s use with any standard WMS service. There are options
> for using WFS as well.
> Are you looking for a cataloging system? Have you looked at GeoNetwork?
> This is also hookable to GeoMoose (A little harder to implement though), but
> as proof:
> https://hub.sharedgeo.org/datasets/GLRI/html/public2/geomoose-glri/geomoose/geomoose.html
> Just click on the Metadata Catalog link in the header to see where some of
> the data comes from.
> Bobb
> From: geomoose-users-bounces at lists.osgeo.org
> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
> Sent: Friday, April 25, 2014 7:24 AM
> To: geomoose-users at lists.osgeo.org
> Subject: [Geomoose-users] Out of the box mapping application for GeoServer
> Hi,
> Is there any out of the box mapping applications for GeoServer that are
> appropriate for local governments. I am looking for an application that is
> somewhat easy to configure, has the basic GIS tools including but not
> limited to search, jump to, identify, etc. Similar to what GeoMOOSE does
> for MapServer http://demo.geomoose.org/master/. It would also be good if
> this application works on desktop and mobile browsers.
> Thank you for your help.
> Sincerely,
> Mark Volz, GISP
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
