[Geomoose-users] printing in GeoMOOSE 2.6.1
Mark Volz MarkVolz at co.lyon.mn.us
Fri Apr 25 08:57:18 PDT 2014
Dan,
My apologies.  I did add a few lines of debugging code, but I am still having trouble even with the original php files.  The line that I am threw the error is "$as_download = $_REQUEST['download'];" which should be around line 37.
Next,
I should further clarify what works and what does not.  The "Parcel Report" works fine.  The "Print Map" service does not.  I tried adjusting the output template, image quality, browser, etc and I have had no luck.  The service create files including a white jpg image, a pdf file that contains "Map" as the title and the standard logo but there map area itself is white.  For an example please see http://demo.geomoose.org/master/php/download.php?id=print_13984411396594&ext=pdf
I think I really need to find out why the print map function is only spitting out a white image.  All of the other features in GeoMOOSE appear to work fine.
Thanks
Sincerely,
Mark Volz, GISP
> -----Original Message-----
> From: Dan Little [mailto:theduckylittle at gmail.com]
> Sent: Friday, April 25, 2014 10:25 AM
> To: Mark Volz
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] printing in GeoMOOSE 2.6.1
> The demo appears to be working fine on GeoMOOSE.org
> (http://demo.geomoose.org/master/).
> Line 43 doesn't look to be particularly suspicious in Git.  Are you sure you
> haven't modified download.php in anyway since downloading it?
> Is your MS4W install using the standard GeoMOOSE package?
> On Fri, Apr 25, 2014 at 7:47 AM, Mark Volz <MarkVolz at co.lyon.mn.us>
> wrote:
> > Hello,
> > I was unable to get printing to work in GeoMOOSE 2.6.1 on my
> > application as well as the demo application on GeoMOOSE.org.
> > download.php reported an
> > error: Notice: Undefined index: download in
> > C:\ms4w\apps\PipestoneMOOSE26\htdocs\php\download.php on line 43.
> > What can I do to fix this error?
> > Thanks
> > Sincerely,
> > Mark Volz, GISP
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
