[Geomoose-users] printing in GeoMOOSE 2.6.1
Dan Little theduckylittle at gmail.com
Fri Apr 25 09:08:45 PDT 2014
http://demo.geomoose.org/master/php/download.php?id=print_13984418346835&ext=html
Printing appears to work fine until you navigate and the views are not
one-for-one.  I'll need to check on something.  It's *very* important
to document the exact steps you take in order to create a bug.  Simply
seeing the output does not generally help on a lot of issues.  The
line-37 errors is interesting.  I'm not getting that error at all on
the demo site.  I would suggest finding your <service ...> definition
and add <param name="download" value="false">.  This bug is happening,
I suspect, due to a few things:
1. Your service definition is different than the one on master.
2. PHP changed how it is handling the $_REQUEST array and is now
throwing a warning/error when a value is undefined.
The blank images are probably due to something disingenuous happening
with the scale.  That I'll need to track down and see who has had
their fingers in the print code.
On Fri, Apr 25, 2014 at 10:57 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
> Dan,
> My apologies.  I did add a few lines of debugging code, but I am still having trouble even with the original php files.  The line that I am threw the error is "$as_download = $_REQUEST['download'];" which should be around line 37.
> Next,
> I should further clarify what works and what does not.  The "Parcel Report" works fine.  The "Print Map" service does not.  I tried adjusting the output template, image quality, browser, etc and I have had no luck.  The service create files including a white jpg image, a pdf file that contains "Map" as the title and the standard logo but there map area itself is white.  For an example please see http://demo.geomoose.org/master/php/download.php?id=print_13984411396594&ext=pdf
> I think I really need to find out why the print map function is only spitting out a white image.  All of the other features in GeoMOOSE appear to work fine.
> Thanks
> Sincerely,
> Mark Volz, GISP
>> -----Original Message-----
>> From: Dan Little [mailto:theduckylittle at gmail.com]
>> Sent: Friday, April 25, 2014 10:25 AM
>> To: Mark Volz
>> Cc: geomoose-users at lists.osgeo.org
>> Subject: Re: [Geomoose-users] printing in GeoMOOSE 2.6.1
>> The demo appears to be working fine on GeoMOOSE.org
>> (http://demo.geomoose.org/master/).
>> Line 43 doesn't look to be particularly suspicious in Git.  Are you sure you
>> haven't modified download.php in anyway since downloading it?
>> Is your MS4W install using the standard GeoMOOSE package?
>> On Fri, Apr 25, 2014 at 7:47 AM, Mark Volz <MarkVolz at co.lyon.mn.us>
>> wrote:
>> > Hello,
>> > I was unable to get printing to work in GeoMOOSE 2.6.1 on my
>> > application as well as the demo application on GeoMOOSE.org.
>> > download.php reported an
>> > error: Notice: Undefined index: download in
>> > C:\ms4w\apps\PipestoneMOOSE26\htdocs\php\download.php on line 43.
>> > What can I do to fix this error?
>> > Thanks
>> > Sincerely,
>> > Mark Volz, GISP
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
