[Geomoose-users] printing in GeoMOOSE 2.6.1
Dan Little theduckylittle at gmail.com
Sun Apr 27 22:00:01 PDT 2014
there may be a fix for this swept up in Issue #37.  We ran into a set
of encoding/decoding/listing issues while fixing internationalization
support.
On Fri, Apr 25, 2014 at 11:08 AM, Dan Little <theduckylittle at gmail.com> wrote:
> http://demo.geomoose.org/master/php/download.php?id=print_13984418346835&ext=html
> Printing appears to work fine until you navigate and the views are not
> one-for-one.  I'll need to check on something.  It's *very* important
> to document the exact steps you take in order to create a bug.  Simply
> seeing the output does not generally help on a lot of issues.  The
> line-37 errors is interesting.  I'm not getting that error at all on
> the demo site.  I would suggest finding your <service ...> definition
> and add <param name="download" value="false">.  This bug is happening,
> I suspect, due to a few things:
> 1. Your service definition is different than the one on master.
> 2. PHP changed how it is handling the $_REQUEST array and is now
> throwing a warning/error when a value is undefined.
> The blank images are probably due to something disingenuous happening
> with the scale.  That I'll need to track down and see who has had
> their fingers in the print code.
> On Fri, Apr 25, 2014 at 10:57 AM, Mark Volz <MarkVolz at co.lyon.mn.us> wrote:
>> Dan,
>> My apologies.  I did add a few lines of debugging code, but I am still having trouble even with the original php files.  The line that I am threw the error is "$as_download = $_REQUEST['download'];" which should be around line 37.
>> Next,
>> I should further clarify what works and what does not.  The "Parcel Report" works fine.  The "Print Map" service does not.  I tried adjusting the output template, image quality, browser, etc and I have had no luck.  The service create files including a white jpg image, a pdf file that contains "Map" as the title and the standard logo but there map area itself is white.  For an example please see http://demo.geomoose.org/master/php/download.php?id=print_13984411396594&ext=pdf
>> I think I really need to find out why the print map function is only spitting out a white image.  All of the other features in GeoMOOSE appear to work fine.
>> Thanks
>> Sincerely,
>> Mark Volz, GISP
>>> -----Original Message-----
>>> From: Dan Little [mailto:theduckylittle at gmail.com]
>>> Sent: Friday, April 25, 2014 10:25 AM
>>> To: Mark Volz
>>> Cc: geomoose-users at lists.osgeo.org
>>> Subject: Re: [Geomoose-users] printing in GeoMOOSE 2.6.1
>>> The demo appears to be working fine on GeoMOOSE.org
>>> (http://demo.geomoose.org/master/).
>>> Line 43 doesn't look to be particularly suspicious in Git.  Are you sure you
>>> haven't modified download.php in anyway since downloading it?
>>> Is your MS4W install using the standard GeoMOOSE package?
>>> On Fri, Apr 25, 2014 at 7:47 AM, Mark Volz <MarkVolz at co.lyon.mn.us>
>>> wrote:
>>> > Hello,
>>> > I was unable to get printing to work in GeoMOOSE 2.6.1 on my
>>> > application as well as the demo application on GeoMOOSE.org.
>>> > download.php reported an
>>> > error: Notice: Undefined index: download in
>>> > C:\ms4w\apps\PipestoneMOOSE26\htdocs\php\download.php on line 43.
>>> > What can I do to fix this error?
>>> > Thanks
>>> > Sincerely,
>>> > Mark Volz, GISP
>>> > _______________________________________________
>>> > Geomoose-users mailing list
>>> > Geomoose-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
