[Geomoose-users] Search Capablility For A Layer with Portuguese special characters
Dan Little
theduckylittle at gmail.com
Wed Apr 30 10:03:17 PDT 2014
André, I just wanted to send you an update on this:
- https://github.com/geomoose/geomoose/issues/37
We've got some tests that prove that trunk works and this fix will be
included in GeoMOOSE 2.7.
On Thu, Mar 13, 2014 at 12:21 PM, André Barriguinha <
andrebarriguinha at agriciencia.com> wrote:
> Yes but that I can overcome by putting the information in PostGIS.
> My main problem is the search capability.
> Yes using 2.6.1
> Regards
> André
> Em 13-03-2014 17:00, Dan Little escreveu:
> Shapefiles are actually *more* problematic because they tend to assume
> ISO-8859-1/Latin-1 encoding. I don't know if Latin-1 has encoding support
> for Portuguese characters. In order of fluency, my languages are English,
> German, and North American Spanish.
> We are trying to put together a new release soon. Which is the constant
> state of GeoMOOSE. Are you using version 2.6.1?
> On Thu, Mar 13, 2014 at 11:55 AM, André Barriguinha <
>> Yes UTF-8
>> You can see the interface here although in Portuguese:
>> http://agriciencia.servehttp.com:1024/riplante/riplante.html
>> I have also the same issues in the identify tool. If i use a shapefile
>> and read directly from the table stored in a folder it doesnt work. If i
>> put them in PostGIS it reads ok and all the special characters are
>> identified.
>> Regards
>> André
>> Em 13-03-2014 16:38, Dan Little escreveu:
>> Hi André,
>> This is an issue with encodings and PHP that I need to work out. I
>> keep forgetting to do it. We've ran into this problem with Russian,
>> Turkish, and German. I can probably create a test case for German. Are
>> you using UTF-8?
>> On Wed, Mar 12, 2014 at 1:01 PM, André Barriguinha <
>>> I'm having trouble setting up the search to a layer when I use
>>> characters like ç ou à
>>> Basicaly writen in Portuguese with some special characters.
>>> The layer is in a PostGIS database and works fine if I search words with
>>> no special characters
>>> Iam using the comparitor like-icase
>>> Regards
>>> André Barriguinha
>>> <http://www.agriciencia.com/> *André Barriguinha*
>>> *Agri-Ciência, Consultores de Engenharia, Lda.*<http://www.agriciencia.com>
>>> Rua dos Lusíadas, 52 - 1º
>>> 1300-372 LISBOA
>>> PORTUGAL
>>> *E-mail: *andrebarriguinha at agriciencia.com
>>> *Telef: *+(351) 213 649 625
>>> *Telm:* +(351) 914 155 278 <%2B%28351%29%20914%20155%20278>
>>> *Fax:* +(351) 213 649 625 <%2B%28351%29%20213%20649%20625>
>>> Geomoose-users mailing list
>>> Geomoose-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140430/79fa04a0/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140430/79fa04a0/attachment-0001.jpe>
More information about the Geomoose-users
