[Geomoose-users] Mouseover features?
TC Haddad tchaddad at gmail.com
Tue Jan 14 16:03:37 PST 2014
Yeah - pretty slick.
it seems like it wouldn't need to be a total re-think for the user. The UTF
grids can be served in parallel with WMS requests, to send over the
important attribute information, so that layers that have "hover" enabled
will have active hotspots. The docs say that you can only have one such
layer active at a time, so it would have to be a radio type switch.
the working UTFGridWMS demo from Google summer of code is here if you
haven't seen it:
http://msgsoc.mapgears.com/utfgridmapserver/openlayers/examples/utfgridwms.html
On Tue, Jan 14, 2014 at 1:57 PM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> All,
> So, I read up on the UTF thing, am I correct in thinking you could
> conceivably use this to apply multiple links per symbol based on the pixel
> values  in the symbol.  Say I used a traffic light symbol
> (red,yellow,green), then I could use each color (or rather that position)
> in the symbol to link to different information, all for the same
> feature/symbol???
> Sounds slick!!
> Bobb
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *Dan Little
> *Sent:* Tuesday, January 14, 2014 10:22 AM
> *To:* Bistrais, Bob
> *Cc:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] Mouseover features?
> We actually have code integrated into the proposed 2.7 that will allow for
> mouse-overs on vector layers.  We've been chatting about UTF Grid support
> but left it off the table for the time being.  I'm in support of adding it
> (since it's becoming increasingly "standard") but UTF Grid additions will
> require some consideration as to how to properly implement in scope of the
> rest of the GeoMOOSE user experience.
> On Fri, Jan 10, 2014 at 10:51 AM, Bistrais, Bob <Bob.Bistrais at maine.gov>
> wrote:
> Thanks Jim.  The fact that it was there, then gone, would explain my
> ambiguous search results.
> I'll refrain from further commentary on that particular browser.
> *From:* James Klassen [klassen.js at gmail.com]
> *Sent:* Friday, January 10, 2014 11:45 AM
> *To:* Bistrais, Bob
> That feature was begrudgingly pulled (at 2.0?) in favor or the identify
> tool because it was causing too much trouble with browser stability.  It
> was image map based and as the image maps got large a certain common
> browser would grind to a halt.
> With newer browsers and techniques, there has been talk of adding it again.
> On Jan 10, 2014 10:00 AM, "Bistrais, Bob" <Bob.Bistrais at maine.gov> wrote:
> Hi,  I've sarched on this topic but but results were confusing- does
> Geomoose (2.6.1) have the ability to do mouseovers of features?  Example-
> hover mousr over a particular feature, see an attribute value of that
> feature.
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140114/5d35d207/attachment-0001.html>
More information about the Geomoose-users mailing list
