[Geomoose-users] epsg:23032 projection error
James Klassen klassen.js at gmail.com
Wed Jan 15 11:32:34 PST 2014
You are probably correct.  Datum transformations are somewhat tricky.
I am assuming:
Your GeoMoose is using EPSG:3857.
You want MapServer to reproject on the fly your data from EPSG:23032 to
EPSG:3857 for display in GeoMoose.
In this case, nothing should need to change regarding projections in
GeoMoose from the demo.  However, you may need to find and install the
correct "datum shift grid" files in the proj4 installation used by
MapServer.  Since QGIS is working for you, I presume it is using a
different installation of proj4 that has the necessary datum shift grid
files.
On 2014/1/15 4:48 AM, Carlo Pelliconi wrote:
> Hi Dan,
> thanks a lot for your interest.
> It seems, in my opinion, a problem while converting from ED50 to WGS84.
> I've tried looking "inside" QGIS (which works properly in reprojecting
> runtime the layer from epsg23032 to epsg3857) for "exporting" the
> solution to geomoose, but I was not able to solve.
> At the moment I work with the layer in epsg32632 and thus in my
> geomoose project (epsg3857) all goes ok, but I'd like to solve also
> starting from epsg23032.
> Any hint is appreciated.
> Thank you!
> With Best Regards
> Carlo
> Il 14/01/2014 17:41, Dan Little ha scritto:
>> Carlo,
>> Did you make any progress on this? I'm just now getting back messages
>> from before the holidays.
>> On Wed, Dec 11, 2013 at 2:42 AM, Carlo Pelliconi
>> <c.pelliconi at sis-ter.it <mailto:c.pelliconi at sis-ter.it>> wrote:
>>     Hi all,
>>     I've an issue with epsg:23032.
>>     When I call a layer in this RefSys in my epsg:3857 geomoose
>>     project, I see wrong positioning of that layer against the other
>>     layers.
>>     If I save the same layer in epsg:32032 and use it in the same
>>     epsg:3857 geomoose project (obviously, managing in the mapfile
>>     the related changes in extent coordinates), the positioning is
>>     correct.
>>     I've also tried changing EPSG23032.js in projection folder, but
>>     with no success.
>>     Is this a known issue? is it available a workaround?
>>     Or, on the other hand, where is my mistake?
>>     Thank you very much for any advice.
>>     With Best Regards,
>>     Carlo
>>     _______________________________________________
>>     Geomoose-users mailing list
>>     Geomoose-users at lists.osgeo.org
>>     <mailto:Geomoose-users at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
> || SIS.TER SRL || Firma ||
> *Carlo Pelliconi*
> Responsabile Sistemi Informativi
> Tel +39 0542 364034 - Fax +39 0542 612130
> c.pelliconi at sis-ter.it <mailto:c.pelliconi at sis-ter.it> -
> www.sis-ter.it <http://www.sis-ter.it>
> SIS.TER SRL <http://www.sis-ter.it> 	Facebook
> <http://www.facebook.com/SIS.TERsrl> 	DEKRA
> Sis.Ter Srl - Via Mentana, 10 - 40026 Imola (BO) 	Reg. n° 141113005
> ATTENZIONE! Le informazioni trasmesse sono da intendersi inviate solo
> ed esclusivamente alla persona alla quale sono state indirizzate e
> possono contenere materiale strettamente confidenziale e/o riservato.
> Qualsiasi utilizzo, ritrasmissione o diffusione delle presenti
> informazioni, anche solo parzialmente, sono proibite a tutte le
> persone o entità diverse dal destinatario. Se ha ricevuto queste
> informazioni per errore, contatti urgentemente il mittente e cancelli
> immediatamente il materiale dal suo computer. Rif. D.L. 196/2003.
> Pensa all'ambiente prima di stampare questo messaggio.
> ATTENTION! The information in this email (which includes any files
> transmitted with it) is confidential and may also be legally
> privileged. It is intended for the addressee only. Access to this
> email by anyone else is unauthorised. It is not to be relied upon by
> any person other than the addressee, except with our prior written
> approval. If no such approval is given, we will not accept any
> liability (in negligence or otherwise) arising from any third party
> acting. Unauthorised recipients are required to maintain
> confidentiality. If you have received this email in error please
> notify us immediately, destroy any copies and delete it from your
> computer system. Any use, forwarding, printing or copying of this
> email is prohibited. Ref. D.L. 196/2003.
> Think about the environment before printing.
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140115/51a70e63/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140115/51a70e63/attachment-0003.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140115/51a70e63/attachment-0004.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140115/51a70e63/attachment-0005.jpe>
More information about the Geomoose-users mailing list
