[Geomoose-users] epsg:23032 projection error
Dan Little theduckylittle at gmail.com
Thu Jan 16 13:43:21 PST 2014
Jim is probably right that supplementing with the correct datum shift files
would help.  I'm out of my comfort zone on making a recommendation.
 GeoMOOSE can be configured to work with any projection if both the source
data and destination projection are the same.
On Wed, Jan 15, 2014 at 1:32 PM, James Klassen <klassen.js at gmail.com> wrote:
>  You are probably correct.  Datum transformations are somewhat tricky.
> I am assuming:
> Your GeoMoose is using EPSG:3857.
> You want MapServer to reproject on the fly your data from EPSG:23032 to
> EPSG:3857 for display in GeoMoose.
> In this case, nothing should need to change regarding projections in
> GeoMoose from the demo.  However, you may need to find and install the
> correct "datum shift grid" files in the proj4 installation used by
> MapServer.  Since QGIS is working for you, I presume it is using a
> different installation of proj4 that has the necessary datum shift grid
> files.
> On 2014/1/15 4:48 AM, Carlo Pelliconi wrote:
> Hi Dan,
> thanks a lot for your interest.
> It seems, in my opinion, a problem while converting from ED50 to WGS84.
> I've tried looking "inside" QGIS (which works properly in reprojecting
> runtime the layer from epsg23032 to epsg3857) for "exporting" the solution
> to geomoose, but I was not able to solve.
> At the moment I work with the layer in epsg32632 and thus in my geomoose
> project (epsg3857) all goes ok, but I'd like to solve also starting from
> epsg23032.
> Any hint is appreciated.
> Thank you!
> With Best Regards
> Carlo
> Il 14/01/2014 17:41, Dan Little ha scritto:
> Carlo,
>  Did you make any progress on this? I'm just now getting back messages
> from before the holidays.
> On Wed, Dec 11, 2013 at 2:42 AM, Carlo Pelliconi <c.pelliconi at sis-ter.it>wrote:
>> Hi all,
>> I've an issue with epsg:23032.
>> When I call a layer in this RefSys in my epsg:3857 geomoose project, I
>> see wrong positioning of that layer against the other layers.
>> If I save the same layer in epsg:32032 and use it in the same epsg:3857
>> geomoose project (obviously, managing in the mapfile the related changes in
>> extent coordinates), the positioning is correct.
>> I've also tried changing EPSG23032.js in projection folder, but with no
>> success.
>> Is this a known issue? is it available a workaround?
>> Or, on the other hand, where is my mistake?
>> Thank you very much for any advice.
>> With Best Regards,
>> Carlo
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>   *Carlo Pelliconi*
> Responsabile Sistemi Informativi
> Tel +39 0542 364034 - Fax +39 0542 612130
> c.pelliconi at sis-ter.it - www.sis-ter.it
>   [image: SIS.TER SRL] <http://www.sis-ter.it> [image: Facebook]<http://www.facebook.com/SIS.TERsrl> [image:
> DEKRA]  Sis.Ter Srl - Via Mentana, 10 - 40026 Imola (BO) Reg. n° 141113005
>    ATTENZIONE! Le informazioni trasmesse sono da intendersi inviate solo
> ed esclusivamente alla persona alla quale sono state indirizzate e possono
> contenere materiale strettamente confidenziale e/o riservato. Qualsiasi
> utilizzo, ritrasmissione o diffusione delle presenti informazioni, anche
> solo parzialmente, sono proibite a tutte le persone o entità diverse dal
> destinatario. Se ha ricevuto queste informazioni per errore, contatti
> urgentemente il mittente e cancelli immediatamente il materiale dal suo
> computer. Rif. D.L. 196/2003.
>  Pensa all'ambiente prima di stampare questo messaggio.
>  ATTENTION! The information in this email (which includes any files
> transmitted with it) is confidential and may also be legally privileged. It
> is intended for the addressee only. Access to this email by anyone else is
> unauthorised. It is not to be relied upon by any person other than the
> addressee, except with our prior written approval. If no such approval is
> given, we will not accept any liability (in negligence or otherwise)
> arising from any third party acting. Unauthorised recipients are required
> to maintain confidentiality. If you have received this email in error
> please notify us immediately, destroy any copies and delete it from your
> computer system. Any use, forwarding, printing or copying of this email is
> prohibited. Ref. D.L. 196/2003.
>  Think about the environment before printing.
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140116/66d5e1d5/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140116/66d5e1d5/attachment-0003.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140116/66d5e1d5/attachment-0004.jpe>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140116/66d5e1d5/attachment-0005.jpe>
More information about the Geomoose-users mailing list
