[Geomoose-users] Search Capablility For A Layer with Portuguese special characters
André Barriguinha andrebarriguinha at agriciencia.com
Thu Mar 13 09:55:35 PDT 2014
Yes UTF-8
You can see the interface here although in Portuguese:
http://agriciencia.servehttp.com:1024/riplante/riplante.html
I have also the same issues in the identify tool. If i use a shapefile
and read directly from the table stored in a folder it doesnt work. If i
put them in PostGIS it reads ok and all the special characters are
identified.
Regards
André
Untitled Document
Em 13-03-2014 16:38, Dan Little escreveu:
> Hi André,
> This is an issue with encodings and PHP that I need to work out.  I
> keep forgetting to do it.  We've ran into this problem with Russian,
> Turkish, and German.  I can probably create a test case for German.
>  Are you using UTF-8?
> On Wed, Mar 12, 2014 at 1:01 PM, André Barriguinha
> <andrebarriguinha at agriciencia.com
> <mailto:andrebarriguinha at agriciencia.com>> wrote:
>     I'm having trouble setting up the search to a layer when I use
>     characters like ç ou à
>     Basicaly writen in Portuguese with some special characters.
>     The layer is in a PostGIS database and works fine if I search
>     words with no special characters
>     Iam using the comparitor like-icase
>     Regards
>     André Barriguinha
>     <http://www.agriciencia.com/> 		*André Barriguinha*
>     */Agri-Ciência, Consultores de Engenharia, Lda./*
>     <http://www.agriciencia.com>
>     Rua dos Lusíadas, 52 - 1º
>     1300-372 LISBOA
>     PORTUGAL
>     *E-mail: *andrebarriguinha at agriciencia.com
>     *Telef: *+(351) 213 649 625
>     *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278>
>     *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625>
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment-0001.jpe>
More information about the Geomoose-users mailing list
