[Geomoose-users] Geomoose-users Digest, Vol 33, Issue 5
Jim Klassen
klassen.js at gmail.com
Thu Mar 13 10:29:08 PDT 2014
+1 on replacing escape() with encodeURIComponent() as escape() is
deprecated and doesn't always handle Unicode correctly [1].
I am not up on the PHP services, but I have to call URI.unescape() on
the parameters in my Ruby services so calling urldecode() in PHP makes
some sense.
Any objections?
[1] http://www.w3schools.com/jsref/jsref_escape.asp
On 03/13/2014 12:13 PM, Michał Chmielewski wrote:
> Hi Andr?,
> If I understand correct you have a problem with special characters
> I had the same problem with eastern europe languages.
> My solution is to change coding: "escape" into "encodeURIComponent" in
> Service.js
> the easy part is to change lines with:
> params[input_name].push( escape(input_value) );
> into
> into
> params[input_name].push( encodeURIComponent(input_value) );
> And the hard part, in every php file, all request change into urldecode
> for example in identyfy.php
> $visibleLayers = $_REQUEST['layers'];
> into
> $visibleLayers = urldecode($_REQUEST['layers']);
> $projection = $_REQUEST['projection'];
> into
> $projection = urldecode($_REQUEST['projection']);
> lot of fun ;)
> but this will make geomoose fit for all languages.
> good lock
> chmielix
> On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org
> <mailto:geomoose-users-request at lists.osgeo.org>> wrote:
> Send Geomoose-users mailing list submissions to
> geomoose-users at lists.osgeo.org <mailto:geomoose-users at lists.osgeo.org>
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geomoose-users-owner at lists.osgeo.org
> <mailto:geomoose-users-owner at lists.osgeo.org>
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Geomoose-users digest..."
> Today's Topics:
> 1. Search Capablility For A Layer with Portuguese special
> characters (Andr? Barriguinha)
> Message: 1
> Date: Thu, 13 Mar 2014 16:55:35 +0000
> From: Andr? Barriguinha <andrebarriguinha at agriciencia.com
> <mailto:andrebarriguinha at agriciencia.com>>
> To: Dan Little <theduckylittle at gmail.com
> <mailto:theduckylittle at gmail.com>>
> Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org
> <mailto:geomoose-users at lists.osgeo.org>>
> Subject: [Geomoose-users] Search Capablility For A Layer with
> Portuguese special characters
> Message-ID: <5321E307.4000509 at agriciencia.com
> <mailto:5321E307.4000509 at agriciencia.com>>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Yes UTF-8
> You can see the interface here although in Portuguese:
> http://agriciencia.servehttp.com:1024/riplante/riplante.html
> I have also the same issues in the identify tool. If i use a shapefile
> and read directly from the table stored in a folder it doesnt
> work. If i
> put them in PostGIS it reads ok and all the special characters are
> identified.
> Regards
> Andr?
> Untitled Document
> Em 13-03-2014 16:38, Dan Little escreveu:
> > Hi Andr?,
> > This is an issue with encodings and PHP that I need to work out. I
> > keep forgetting to do it. We've ran into this problem with Russian,
> > Turkish, and German. I can probably create a test case for German.
> > Are you using UTF-8?
> > On Wed, Mar 12, 2014 at 1:01 PM, Andr? Barriguinha
> <mailto:andrebarriguinha at agriciencia.com>>> wrote:
> > I'm having trouble setting up the search to a layer when I use
> > characters like ? ou ?
> > Basicaly writen in Portuguese with some special characters.
> > The layer is in a PostGIS database and works fine if I search
> > words with no special characters
> > Iam using the comparitor like-icase
> > Regards
> > Andr? Barriguinha
> > <http://www.agriciencia.com/> *Andr? Barriguinha*
> > */Agri-Ci?ncia, Consultores de Engenharia, Lda./*
> > <http://www.agriciencia.com>
> > Rua dos Lus?adas, 52 - 1?
> > 1300-372 LISBOA
> > PORTUGAL
> > *E-mail: *andrebarriguinha at agriciencia.com
> > *Telef: *+(351) 213 649 625
> > *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278>
> > *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625>
> > Geomoose-users at lists.osgeo.org
> <mailto:Geomoose-users at lists.osgeo.org>
> <mailto:Geomoose-users at lists.osgeo.org>>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html>
> A non-text attachment was scrubbed...
> Name: not available
> Type: image/jpeg
> Desc: not available
> URL:
> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe>
> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
> End of Geomoose-users Digest, Vol 33, Issue 5
> Michał Chmielewski
> mich.chmielewski at gmail.com <mailto:mich.chmielewski at gmail.com>
More information about the Geomoose-users
