[Geomoose-users] Geomoose-users Digest, Vol 33, Issue 5
Michał Chmielewski mich.chmielewski at gmail.com
Thu Mar 13 10:13:37 PDT 2014
Hi Andr?,
If I understand correct you have a problem with special characters
I had the same problem with eastern europe languages.
My solution is to change coding: "escape" into "encodeURIComponent" in
Service.js
the easy part is to change lines with:
params[input_name].push( escape(input_value) );
into
into
params[input_name].push( encodeURIComponent(input_value) );
And the hard part, in every php file, all request change into urldecode
for example in identyfy.php
$visibleLayers = $_REQUEST['layers'];
into
$visibleLayers = urldecode($_REQUEST['layers']);
$projection = $_REQUEST['projection'];
into
$projection = urldecode($_REQUEST['projection']);
lot of fun ;)
but this will make geomoose fit for all languages.
good lock
chmielix
On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org> wrote:
> Send Geomoose-users mailing list submissions to
>         geomoose-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         geomoose-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Geomoose-users digest..."
> Today's Topics:
>    1. Search Capablility For A Layer with Portuguese    special
>       characters (Andr? Barriguinha)
> Message: 1
> Date: Thu, 13 Mar 2014 16:55:35 +0000
> From: Andr? Barriguinha <andrebarriguinha at agriciencia.com>
> To: Dan Little <theduckylittle at gmail.com>
> Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> Subject: [Geomoose-users] Search Capablility For A Layer with
>         Portuguese      special characters
> Message-ID: <5321E307.4000509 at agriciencia.com>
> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> Yes UTF-8
> You can see the interface here although in Portuguese:
> http://agriciencia.servehttp.com:1024/riplante/riplante.html
> I have also the same issues in the identify tool. If i use a shapefile
> and read directly from the table stored in a folder it doesnt work. If i
> put them in PostGIS it reads ok and all the special characters are
> identified.
> Regards
> Andr?
> Untitled Document
> Em 13-03-2014 16:38, Dan Little escreveu:
> > Hi Andr?,
> > This is an issue with encodings and PHP that I need to work out.  I
> > keep forgetting to do it.  We've ran into this problem with Russian,
> > Turkish, and German.  I can probably create a test case for German.
> >  Are you using UTF-8?
> > On Wed, Mar 12, 2014 at 1:01 PM, Andr? Barriguinha
> > <mailto:andrebarriguinha at agriciencia.com>> wrote:
> >     I'm having trouble setting up the search to a layer when I use
> >     characters like ? ou ?
> >     Basicaly writen in Portuguese with some special characters.
> >     The layer is in a PostGIS database and works fine if I search
> >     words with no special characters
> >     Iam using the comparitor like-icase
> >     Regards
> >     Andr? Barriguinha
> >     <http://www.agriciencia.com/>             *Andr? Barriguinha*
> >     */Agri-Ci?ncia, Consultores de Engenharia, Lda./*
> >     <http://www.agriciencia.com>
> >     Rua dos Lus?adas, 52 - 1?
> >     1300-372 LISBOA
> >     PORTUGAL
> >     *E-mail: *andrebarriguinha at agriciencia.com
> >     *Telef: *+(351) 213 649 625
> >     *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278>
> >     *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625>
> >     _______________________________________________
> >     Geomoose-users at lists.osgeo.org <mailto:
> Geomoose-users at lists.osgeo.org>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html
> A non-text attachment was scrubbed...
> Name: not available
> Type: image/jpeg
> Desc: not available
> URL: <
> http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe
> End of Geomoose-users Digest, Vol 33, Issue 5
Michał Chmielewski
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/a93565ac/attachment.html>
More information about the Geomoose-users mailing list
