[Geomoose-users] Search Capablility For A Layer with Portuguese special characters
André Barriguinha
andrebarriguinha at agriciencia.com
Thu Mar 13 10:21:20 PDT 2014
Yes but that I canovercome by putting the information in PostGIS.
My main problem is the search capability.
Yes using 2.6.1
Regards
André
Untitled Document
Em 13-03-2014 17:00, Dan Little escreveu:
> Shapefiles are actually *more* problematic because they tend to assume
> ISO-8859-1/Latin-1 encoding. I don't know if Latin-1 has encoding
> support for Portuguese characters. In order of fluency, my languages
> are English, German, and North American Spanish.
> We are trying to put together a new release soon. Which is the
> constant state of GeoMOOSE. Are you using version 2.6.1?
> On Thu, Mar 13, 2014 at 11:55 AM, André Barriguinha
> <andrebarriguinha at agriciencia.com
> <mailto:andrebarriguinha at agriciencia.com>> wrote:
> Yes UTF-8
> You can see the interface here although in Portuguese:
> http://agriciencia.servehttp.com:1024/riplante/riplante.html
> I have also the same issues in the identify tool. If i use a
> shapefile and read directly from the table stored in a folder it
> doesnt work. If i put them in PostGIS it reads ok and all the
> special characters are identified.
> Regards
> André
> Em 13-03-2014 16:38, Dan Little escreveu:
>> Hi André,
>> This is an issue with encodings and PHP that I need to work out.
>> I keep forgetting to do it. We've ran into this problem with
>> Russian, Turkish, and German. I can probably create a test case
>> for German. Are you using UTF-8?
>> On Wed, Mar 12, 2014 at 1:01 PM, André Barriguinha
>> I'm having trouble setting up the search to a layer when I
>> use characters like ç ou à
>> Basicaly writen in Portuguese with some special characters.
>> The layer is in a PostGIS database and works fine if I search
>> words with no special characters
>> Iam using the comparitor like-icase
>> Regards
>> André Barriguinha
>> <http://www.agriciencia.com/> *André Barriguinha*
>> */Agri-Ciência, Consultores de Engenharia, Lda./*
>> <http://www.agriciencia.com>
>> Rua dos Lusíadas, 52 - 1º
>> 1300-372 LISBOA
>> PORTUGAL
>> *E-mail: *andrebarriguinha at agriciencia.com
>> *Telef: *+(351) 213 649 625
>> *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278>
>> *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625>
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> <mailto:Geomoose-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/2e65c42f/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/2e65c42f/attachment-0001.jpe>
More information about the Geomoose-users
