[Geomoose-users] Search Capablility For A Layer with Portuguese special characters
André Barriguinha
andrebarriguinha at agriciencia.com
Fri Mar 14 02:22:45 PDT 2014
Thank you for the replies.
But the problem pressists even with encodeURIComponent()
Here are the parameters that are send when I search for "bragança"
> comparitor0 |like-icase|
> dojo.preventCache |1394788474941|
> fieldname0 |distrito|
> highlight |true|
> layer0 |caop/caop|
> mode |search|
> template0 |itemquery|
> value0 |bragan%E7a|
The value that is sent is not ok
Regards
André
Untitled Document
Em 13-03-2014 19:00, geomoose-users-request at lists.osgeo.org escreveu:
> Send Geomoose-users mailing list submissions to
> geomoose-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geomoose-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Geomoose-users digest..."
> Today's Topics:
> 1. Re: Geomoose-users Digest, Vol 33, Issue 5 (Jim Klassen)
> Message: 1
> Date: Thu, 13 Mar 2014 12:29:08 -0500
> From: Jim Klassen <klassen.js at gmail.com>
> To: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 33, Issue 5
> Message-ID: <5321EAE4.2070905 at gmail.com>
> Content-Type: text/plain; charset=UTF-8
> +1 on replacing escape() with encodeURIComponent() as escape() is
> deprecated and doesn't always handle Unicode correctly [1].
> I am not up on the PHP services, but I have to call URI.unescape() on
> the parameters in my Ruby services so calling urldecode() in PHP makes
> some sense.
> Any objections?
> [1] http://www.w3schools.com/jsref/jsref_escape.asp
> On 03/13/2014 12:13 PM, Micha? Chmielewski wrote:
>> Hi Andr?,
>> If I understand correct you have a problem with special characters
>> I had the same problem with eastern europe languages.
>> My solution is to change coding: "escape" into "encodeURIComponent" in
>> Service.js
>> the easy part is to change lines with:
>> params[input_name].push( escape(input_value) );
>> into
>> into
>> params[input_name].push( encodeURIComponent(input_value) );
>> And the hard part, in every php file, all request change into urldecode
>> for example in identyfy.php
>> $visibleLayers = $_REQUEST['layers'];
>> into
>> $visibleLayers = urldecode($_REQUEST['layers']);
>> $projection = $_REQUEST['projection'];
>> into
>> $projection = urldecode($_REQUEST['projection']);
>> lot of fun ;)
>> but this will make geomoose fit for all languages.
>> good lock
>> chmielix
>> On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org
>> geomoose-users at lists.osgeo.org <mailto:geomoose-users at lists.osgeo.org>
>> <mailto:geomoose-users-owner at lists.osgeo.org>
>> Today's Topics:
>> 1. Search Capablility For A Layer with Portuguese special
>> characters (Andr? Barriguinha)
>> Message: 1
>> Date: Thu, 13 Mar 2014 16:55:35 +0000
>> From: Andr? Barriguinha <andrebarriguinha at agriciencia.com
>> <mailto:andrebarriguinha at agriciencia.com>>
>> To: Dan Little <theduckylittle at gmail.com
>> <mailto:theduckylittle at gmail.com>>
>> Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org
>> <mailto:geomoose-users at lists.osgeo.org>>
>> Subject: [Geomoose-users] Search Capablility For A Layer with
>> Message-ID: <5321E307.4000509 at agriciencia.com
>> <mailto:5321E307.4000509 at agriciencia.com>>
>> Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
>> Yes UTF-8
>> You can see the interface here although in Portuguese:
>> http://agriciencia.servehttp.com:1024/riplante/riplante.html
>> I have also the same issues in the identify tool. If i use a shapefile
>> and read directly from the table stored in a folder it doesnt
>> work. If i
>> put them in PostGIS it reads ok and all the special characters are
>> identified.
>> Regards
>> Andr?
>> Untitled Document
>> Em 13-03-2014 16:38, Dan Little escreveu:
>> > Hi Andr?,
>> > This is an issue with encodings and PHP that I need to work out. I
>> > keep forgetting to do it. We've ran into this problem with Russian,
>> > Turkish, and German. I can probably create a test case for German.
>> > Are you using UTF-8?
>> > On Wed, Mar 12, 2014 at 1:01 PM, Andr? Barriguinha
>> <mailto:andrebarriguinha at agriciencia.com>>> wrote:
>> > I'm having trouble setting up the search to a layer when I use
>> > characters like ? ou ?
>> > Basicaly writen in Portuguese with some special characters.
>> > The layer is in a PostGIS database and works fine if I search
>> > words with no special characters
>> > Iam using the comparitor like-icase
>> > Regards
>> > Andr? Barriguinha
>> > <http://www.agriciencia.com/> *Andr? Barriguinha*
>> > */Agri-Ci?ncia, Consultores de Engenharia, Lda./*
>> > <http://www.agriciencia.com>
>> > Rua dos Lus?adas, 52 - 1?
>> > 1300-372 LISBOA
>> > PORTUGAL
>> > *E-mail: *andrebarriguinha at agriciencia.com
>> > *Telef: *+(351) 213 649 625
>> > *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278>
>> > *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625>
>> > _______________________________________________
>> > Geomoose-users at lists.osgeo.org
>> <mailto:Geomoose-users at lists.osgeo.org>
>> <mailto:Geomoose-users at lists.osgeo.org>>
>> -------------- next part --------------
>> An HTML attachment was scrubbed...
>> URL:
>> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html>
>> A non-text attachment was scrubbed...
>> Name: not available
>> Type: image/jpeg
>> Desc: not available
>> URL:
>> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe>
>> Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>> End of Geomoose-users Digest, Vol 33, Issue 5
>> Micha? Chmielewski
>> mich.chmielewski at gmail.com <mailto:mich.chmielewski at gmail.com>
> End of Geomoose-users Digest, Vol 33, Issue 8
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140314/8f6f47f2/attachment-0001.html>
More information about the Geomoose-users
