[Geomoose-users] Search Capablility For A Layer with Portuguese special characters
James Klassen klassen.js at gmail.com
Fri Mar 14 07:08:33 PDT 2014
In geomoose.html, is the charset=ISO-8859-1 or UTF-8?
0xE7 is correct in ISO-8859-1.
IIRC I changed this to UTF-8 once but it got reverted because it broke
something for some people deploying/editing files on Windows.
On Mar 14, 2014 4:22 AM, "André Barriguinha" <
andrebarriguinha at agriciencia.com> wrote:
>  Hi,
> Thank you for the replies.
> But the problem pressists even with encodeURIComponent()
> Here are the parameters that are send when I search for "bragança"
>   comparitor0 like-icase  dojo.preventCache 1394788474941  fieldname0
> distrito  highlight true  layer0 caop/caop  mode search  template0
> itemquery  value0 bragan%E7a
> The value that is sent is not ok
> Regards
> André
>  Em 13-03-2014 19:00, geomoose-users-request at lists.osgeo.org escreveu:
> Send Geomoose-users mailing list submissions to
> 	geomoose-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> 	http://lists.osgeo.org/mailman/listinfo/geomoose-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> 	geomoose-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Geomoose-users digest..."
> Today's Topics:
>    1. Re: Geomoose-users Digest, Vol 33, Issue 5 (Jim Klassen)
> Message: 1
> Date: Thu, 13 Mar 2014 12:29:08 -0500
> From: Jim Klassen <klassen.js at gmail.com> <klassen.js at gmail.com>
> To: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 33, Issue 5
> Message-ID: <5321EAE4.2070905 at gmail.com> <5321EAE4.2070905 at gmail.com>
> Content-Type: text/plain; charset=UTF-8
> +1 on replacing escape() with encodeURIComponent() as escape() is
> deprecated and doesn't always handle Unicode correctly [1].
> I am not up on the PHP services, but I have to call URI.unescape() on
> the parameters in my Ruby services so calling urldecode() in PHP makes
> some sense.
> Any objections?
> [1] http://www.w3schools.com/jsref/jsref_escape.asp
> On 03/13/2014 12:13 PM, Micha? Chmielewski wrote:
>  Hi Andr?,
> If I understand correct you have a problem with special characters
> I had the same problem with eastern europe languages.
> My solution is to change coding: "escape" into "encodeURIComponent" in
> Service.js
> the easy part is to change lines with:
> params[input_name].push( escape(input_value) );
> into
> into
> params[input_name].push( encodeURIComponent(input_value) );
> And the hard part, in every php file, all request change into urldecode
> for example in identyfy.php
> $visibleLayers = $_REQUEST['layers'];
> into
> $visibleLayers = urldecode($_REQUEST['layers']);
> $projection = $_REQUEST['projection'];
> into
> $projection = urldecode($_REQUEST['projection']);
> lot of fun ;)
> but this will make geomoose fit for all languages.
> good lock
> chmielix
> On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org<mailto:geomoose-users-request at lists.osgeo.org> <geomoose-users-request at lists.osgeo.org>> wrote:
>     geomoose-users at lists.osgeo.org <mailto:geomoose-users at lists.osgeo.org> <geomoose-users at lists.osgeo.org>
>     <mailto:geomoose-users-owner at lists.osgeo.org> <geomoose-users-owner at lists.osgeo.org>
>     Today's Topics:
>     1. Search Capablility For A Layer with Portuguese special
>     characters (Andr? Barriguinha)
>     Message: 1
>     Date: Thu, 13 Mar 2014 16:55:35 +0000
>     From: Andr? Barriguinha <andrebarriguinha at agriciencia.com
>     <mailto:andrebarriguinha at agriciencia.com> <andrebarriguinha at agriciencia.com>>
>     To: Dan Little <theduckylittle at gmail.com
>     <mailto:theduckylittle at gmail.com> <theduckylittle at gmail.com>>
>     Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org
>     <mailto:geomoose-users at lists.osgeo.org> <geomoose-users at lists.osgeo.org>>
>     Subject: [Geomoose-users] Search Capablility For A Layer with
>     Message-ID: <5321E307.4000509 at agriciencia.com
>     <mailto:5321E307.4000509 at agriciencia.com> <5321E307.4000509 at agriciencia.com>>
>     Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
>     Yes UTF-8
>     You can see the interface here although in Portuguese:
>     http://agriciencia.servehttp.com:1024/riplante/riplante.html
>     I have also the same issues in the identify tool. If i use a shapefile
>     and read directly from the table stored in a folder it doesnt
>     work. If i
>     put them in PostGIS it reads ok and all the special characters are
>     identified.
>     Regards
>     Andr?
>     Untitled Document
>     Em 13-03-2014 16:38, Dan Little escreveu:
>     > Hi Andr?,
>     > This is an issue with encodings and PHP that I need to work out. I
>     > keep forgetting to do it. We've ran into this problem with Russian,
>     > Turkish, and German. I can probably create a test case for German.
>     > Are you using UTF-8?
>     > On Wed, Mar 12, 2014 at 1:01 PM, Andr? Barriguinha
>     > <mailto:andrebarriguinha at agriciencia.com <andrebarriguinha at agriciencia.com>
>     <mailto:andrebarriguinha at agriciencia.com> <andrebarriguinha at agriciencia.com>>> wrote:
>     > I'm having trouble setting up the search to a layer when I use
>     > characters like ? ou ?
>     > Basicaly writen in Portuguese with some special characters.
>     > The layer is in a PostGIS database and works fine if I search
>     > words with no special characters
>     > Iam using the comparitor like-icase
>     > Regards
>     > Andr? Barriguinha
>     > <http://www.agriciencia.com/> <http://www.agriciencia.com/> *Andr? Barriguinha*
>     > */Agri-Ci?ncia, Consultores de Engenharia, Lda./*
>     > <http://www.agriciencia.com> <http://www.agriciencia.com>
>     > Rua dos Lus?adas, 52 - 1?
>     > 1300-372 LISBOA
>     > PORTUGAL
>     > *E-mail: *andrebarriguinha at agriciencia.com
>     > *Telef: *+(351) 213 649 625
>     > *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278> <%2B%28351%29%20914%20155%20278>
>     > *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625> <%2B%28351%29%20213%20649%20625>
>     > _______________________________________________
>     > Geomoose-users at lists.osgeo.org
>     <mailto:Geomoose-users at lists.osgeo.org> <Geomoose-users at lists.osgeo.org>
>     <mailto:Geomoose-users at lists.osgeo.org <Geomoose-users at lists.osgeo.org>
>     <mailto:Geomoose-users at lists.osgeo.org> <Geomoose-users at lists.osgeo.org>>
>     -------------- next part --------------
>     An HTML attachment was scrubbed...
>     URL:
>     <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html>
>     A non-text attachment was scrubbed...
>     Name: not available
>     Type: image/jpeg
>     Desc: not available
>     URL:
>     <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe> <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe>
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org> <Geomoose-users at lists.osgeo.org>
>     End of Geomoose-users Digest, Vol 33, Issue 5
> Micha? Chmielewskimich.chmielewski at gmail.com <mailto:mich.chmielewski at gmail.com> <mich.chmielewski at gmail.com>
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
> End of Geomoose-users Digest, Vol 33, Issue 8
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140314/5983c87e/attachment.html>
More information about the Geomoose-users mailing list
