[Geomoose-users] Search Capablility For A Layer with Portuguese special characters
André Barriguinha andrebarriguinha at agriciencia.com
Fri Mar 14 07:29:47 PDT 2014
ISO-8859-1
But if I change to UTF-8 is the same
Regards
André
Em 14-03-2014 14:08, James Klassen escreveu:
> In geomoose.html, is the charset=ISO-8859-1 or UTF-8?
> 0xE7 is correct in ISO-8859-1.
> IIRC I changed this to UTF-8 once but it got reverted because it broke
> something for some people deploying/editing files on Windows.
> On Mar 14, 2014 4:22 AM, "André Barriguinha"
> <andrebarriguinha at agriciencia.com
> <mailto:andrebarriguinha at agriciencia.com>> wrote:
>     Hi,
>     Thank you for the replies.
>     But the problem pressists even with encodeURIComponent()
>     Here are the parameters that are send when I search for "bragança"
>>     comparitor0 	|like-icase|
>>     dojo.preventCache 	|1394788474941|
>>     fieldname0 	|distrito|
>>     highlight 	|true|
>>     layer0 	|caop/caop|
>>     mode 	|search|
>>     template0 	|itemquery|
>>     value0 	|bragan%E7a|
>     The value that is sent is not ok
>     Regards
>     André
>     Em 13-03-2014 19:00, geomoose-users-request at lists.osgeo.org
>     <mailto:geomoose-users-request at lists.osgeo.org> escreveu:
>>     Send Geomoose-users mailing list submissions to
>>     	geomoose-users at lists.osgeo.org  <mailto:geomoose-users at lists.osgeo.org>
>>     To subscribe or unsubscribe via the World Wide Web, visit
>>     	http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>     or, via email, send a message with subject or body 'help' to
>>     	geomoose-users-request at lists.osgeo.org  <mailto:geomoose-users-request at lists.osgeo.org>
>>     You can reach the person managing the list at
>>     	geomoose-users-owner at lists.osgeo.org  <mailto:geomoose-users-owner at lists.osgeo.org>
>>     When replying, please edit your Subject line so it is more specific
>>     than "Re: Contents of Geomoose-users digest..."
>>     Today's Topics:
>>         1. Re: Geomoose-users Digest, Vol 33, Issue 5 (Jim Klassen)
>>     Message: 1
>>     Date: Thu, 13 Mar 2014 12:29:08 -0500
>>     From: Jim Klassen<klassen.js at gmail.com>  <mailto:klassen.js at gmail.com>
>>     To:geomoose-users at lists.osgeo.org  <mailto:geomoose-users at lists.osgeo.org>
>>     Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 33, Issue 5
>>     Message-ID:<5321EAE4.2070905 at gmail.com>  <mailto:5321EAE4.2070905 at gmail.com>
>>     Content-Type: text/plain; charset=UTF-8
>>     +1 on replacing escape() with encodeURIComponent() as escape() is
>>     deprecated and doesn't always handle Unicode correctly [1].
>>     I am not up on the PHP services, but I have to call URI.unescape() on
>>     the parameters in my Ruby services so calling urldecode() in PHP makes
>>     some sense.
>>     Any objections?
>>     [1]http://www.w3schools.com/jsref/jsref_escape.asp
>>     On 03/13/2014 12:13 PM, Micha? Chmielewski wrote:
>>>     Hi Andr?,
>>>     If I understand correct you have a problem with special characters
>>>     I had the same problem with eastern europe languages.
>>>     My solution is to change coding: "escape" into "encodeURIComponent" in
>>>     Service.js
>>>     the easy part is to change lines with:
>>>     params[input_name].push( escape(input_value) );
>>>     into
>>>     into
>>>     params[input_name].push( encodeURIComponent(input_value) );
>>>     And the hard part, in every php file, all request change into urldecode
>>>     for example in identyfy.php
>>>     $visibleLayers = $_REQUEST['layers'];
>>>     into
>>>     $visibleLayers = urldecode($_REQUEST['layers']);
>>>     $projection = $_REQUEST['projection'];
>>>     into
>>>     $projection = urldecode($_REQUEST['projection']);
>>>     lot of fun ;)
>>>     but this will make geomoose fit for all languages.
>>>     good lock
>>>     chmielix
>>>     On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org  <mailto:geomoose-users-request at lists.osgeo.org>
>>>     <mailto:geomoose-users-request at lists.osgeo.org>  <mailto:geomoose-users-request at lists.osgeo.org>> wrote:
>>>          geomoose-users at lists.osgeo.org  <mailto:geomoose-users at lists.osgeo.org>  <mailto:geomoose-users at lists.osgeo.org>  <mailto:geomoose-users at lists.osgeo.org>
>>>          <mailto:geomoose-users-owner at lists.osgeo.org>  <mailto:geomoose-users-owner at lists.osgeo.org>
>>>          Today's Topics:
>>>          1. Search Capablility For A Layer with Portuguese special
>>>          characters (Andr? Barriguinha)
>>>          Message: 1
>>>          Date: Thu, 13 Mar 2014 16:55:35 +0000
>>>          From: Andr? Barriguinha <andrebarriguinha at agriciencia.com  <mailto:andrebarriguinha at agriciencia.com>
>>>          <mailto:andrebarriguinha at agriciencia.com>  <mailto:andrebarriguinha at agriciencia.com>>
>>>          To: Dan Little <theduckylittle at gmail.com  <mailto:theduckylittle at gmail.com>
>>>          <mailto:theduckylittle at gmail.com>  <mailto:theduckylittle at gmail.com>>
>>>          Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org  <mailto:geomoose-users at lists.osgeo.org>
>>>          <mailto:geomoose-users at lists.osgeo.org>  <mailto:geomoose-users at lists.osgeo.org>>
>>>          Subject: [Geomoose-users] Search Capablility For A Layer with
>>>          Message-ID: <5321E307.4000509 at agriciencia.com  <mailto:5321E307.4000509 at agriciencia.com>
>>>          <mailto:5321E307.4000509 at agriciencia.com>  <mailto:5321E307.4000509 at agriciencia.com>>
>>>          Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
>>>          Yes UTF-8
>>>          You can see the interface here although in Portuguese:
>>>          http://agriciencia.servehttp.com:1024/riplante/riplante.html
>>>          I have also the same issues in the identify tool. If i use a shapefile
>>>          and read directly from the table stored in a folder it doesnt
>>>          work. If i
>>>          put them in PostGIS it reads ok and all the special characters are
>>>          identified.
>>>          Regards
>>>          Andr?
>>>          Untitled Document
>>>          Em 13-03-2014 16:38, Dan Little escreveu:
>>>          > Hi Andr?,
>>>          > This is an issue with encodings and PHP that I need to work out. I
>>>          > keep forgetting to do it. We've ran into this problem with Russian,
>>>          > Turkish, and German. I can probably create a test case for German.
>>>          > Are you using UTF-8?
>>>          > On Wed, Mar 12, 2014 at 1:01 PM, Andr? Barriguinha
>>>          <mailto:andrebarriguinha at agriciencia.com>  <mailto:andrebarriguinha at agriciencia.com>>> wrote:
>>>          > I'm having trouble setting up the search to a layer when I use
>>>          > characters like ? ou ?
>>>          > Basicaly writen in Portuguese with some special characters.
>>>          > The layer is in a PostGIS database and works fine if I search
>>>          > words with no special characters
>>>          > Iam using the comparitor like-icase
>>>          > Regards
>>>          > Andr? Barriguinha
>>>          ><http://www.agriciencia.com/>  <http://www.agriciencia.com/>  *Andr? Barriguinha*
>>>          > */Agri-Ci?ncia, Consultores de Engenharia, Lda./*
>>>          ><http://www.agriciencia.com>  <http://www.agriciencia.com>
>>>          > Rua dos Lus?adas, 52 - 1?
>>>          > 1300-372 LISBOA
>>>          > PORTUGAL
>>>          > *E-mail: *andrebarriguinha at agriciencia.com  <mailto:andrebarriguinha at agriciencia.com>
>>>          > *Telef: *+(351) 213 649 625  <tel:%2B%28351%29%20213%20649%20625>
>>>          > *Telm:*+(351) 914 155 278  <tel:%2B%28351%29%20914%20155%20278>  <tel:%2B%28351%29%20914%20155%20278>  <tel:%2B%28351%29%20914%20155%20278>
>>>          > *Fax:*+(351) 213 649 625  <tel:%2B%28351%29%20213%20649%20625>  <tel:%2B%28351%29%20213%20649%20625>  <tel:%2B%28351%29%20213%20649%20625>
>>>          > _______________________________________________
>>>          >Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>>>          <mailto:Geomoose-users at lists.osgeo.org>  <mailto:Geomoose-users at lists.osgeo.org>
>>>          <mailto:Geomoose-users at lists.osgeo.org>  <mailto:Geomoose-users at lists.osgeo.org>>
>>>          -------------- next part --------------
>>>          An HTML attachment was scrubbed...
>>>          URL:
>>>          <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html>  <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html>
>>>          A non-text attachment was scrubbed...
>>>          Name: not available
>>>          Type: image/jpeg
>>>          Desc: not available
>>>          URL:
>>>          <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe>  <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe>
>>>          Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>  <mailto:Geomoose-users at lists.osgeo.org>  <mailto:Geomoose-users at lists.osgeo.org>
>>>          End of Geomoose-users Digest, Vol 33, Issue 5
>>>     Micha? Chmielewski
>>>     mich.chmielewski at gmail.com  <mailto:mich.chmielewski at gmail.com>  <mailto:mich.chmielewski at gmail.com>  <mailto:mich.chmielewski at gmail.com>
>>     End of Geomoose-users Digest, Vol 33, Issue 8
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140314/622938be/attachment-0001.html>
More information about the Geomoose-users mailing list
