[Geomoose-users] Geomoose-users Digest, Vol 33, Issue 10
Michał Chmielewski mich.chmielewski at gmail.com
Fri Mar 14 09:13:44 PDT 2014
it looks like not all is encoded using encodeURIcomponent.
layer0 caop/caop should be caop%252Fcaop
Is it a postgis layer? can you find any values without special chracters?
On 14 March 2014 15:29, <geomoose-users-request at lists.osgeo.org> wrote:
> Send Geomoose-users mailing list submissions to
>         geomoose-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/geomoose-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         geomoose-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Geomoose-users digest..."
> Today's Topics:
>    1. Re: Search Capablility For A Layer with Portuguese special
>       characters (James Klassen)
>    2. Re: Search Capablility For A Layer with Portuguese special
>       characters (Andr? Barriguinha)
> Message: 1
> Date: Fri, 14 Mar 2014 09:08:33 -0500
> From: James Klassen <klassen.js at gmail.com>
> To: Andr? Barriguinha <andrebarriguinha at agriciencia.com>
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Search Capablility For A Layer with
>         Portuguese special characters
> Message-ID:
>         <CAHqX795+bi8CL+Z9+r9M=6v2Z7GfzWRc=
> 5bqeLCN5SjZVLGuiw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> In geomoose.html, is the charset=ISO-8859-1 or UTF-8?
> 0xE7 is correct in ISO-8859-1.
> IIRC I changed this to UTF-8 once but it got reverted because it broke
> something for some people deploying/editing files on Windows.
> On Mar 14, 2014 4:22 AM, "Andr? Barriguinha" <
> andrebarriguinha at agriciencia.com> wrote:
> >  Hi,
> > Thank you for the replies.
> > But the problem pressists even with encodeURIComponent()
> > Here are the parameters that are send when I search for "bragan?a"
> >   comparitor0 like-icase  dojo.preventCache 1394788474941  fieldname0
> > distrito  highlight true  layer0 caop/caop  mode search  template0
> > itemquery  value0 bragan%E7a
> > The value that is sent is not ok
> > Regards
> > Andr?
> >  Em 13-03-2014 19:00, geomoose-users-request at lists.osgeo.org escreveu:
> > Today's Topics:
> >    1. Re: Geomoose-users Digest, Vol 33, Issue 5 (Jim Klassen)
> > Message: 1
> > Date: Thu, 13 Mar 2014 12:29:08 -0500
> > From: Jim Klassen <klassen.js at gmail.com> <klassen.js at gmail.com>
> > To: geomoose-users at lists.osgeo.org
> > Subject: Re: [Geomoose-users] Geomoose-users Digest, Vol 33, Issue 5
> > Message-ID: <5321EAE4.2070905 at gmail.com> <5321EAE4.2070905 at gmail.com>
> > Content-Type: text/plain; charset=UTF-8
> > +1 on replacing escape() with encodeURIComponent() as escape() is
> > deprecated and doesn't always handle Unicode correctly [1].
> > I am not up on the PHP services, but I have to call URI.unescape() on
> > the parameters in my Ruby services so calling urldecode() in PHP makes
> > some sense.
> > Any objections?
> > [1] http://www.w3schools.com/jsref/jsref_escape.asp
> > On 03/13/2014 12:13 PM, Micha? Chmielewski wrote:
> >  Hi Andr?,
> > If I understand correct you have a problem with special characters
> > I had the same problem with eastern europe languages.
> > My solution is to change coding: "escape" into "encodeURIComponent" in
> > Service.js
> > the easy part is to change lines with:
> > params[input_name].push( escape(input_value) );
> > into
> > into
> > params[input_name].push( encodeURIComponent(input_value) );
> > And the hard part, in every php file, all request change into urldecode
> > for example in identyfy.php
> > $visibleLayers = $_REQUEST['layers'];
> > into
> > $visibleLayers = urldecode($_REQUEST['layers']);
> > $projection = $_REQUEST['projection'];
> > into
> > $projection = urldecode($_REQUEST['projection']);
> > lot of fun ;)
> > but this will make geomoose fit for all languages.
> > good lock
> > chmielix
> > On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org<mailto:
> geomoose-users-request at lists.osgeo.org> <
> >     geomoose-users at lists.osgeo.org <mailto:
> geomoose-users at lists.osgeo.org> <geomoose-users at lists.osgeo.org>
> >     <mailto:geomoose-users-request at lists.osgeo.org> <
> >     <mailto:geomoose-users-owner at lists.osgeo.org> <
> >     Today's Topics:
> >     1. Search Capablility For A Layer with Portuguese special
> >     Message: 1
> >     Date: Thu, 13 Mar 2014 16:55:35 +0000
> >     From: Andr? Barriguinha <andrebarriguinha at agriciencia.com
> >     <mailto:andrebarriguinha at agriciencia.com> <
> andrebarriguinha at agriciencia.com>>
> >     To: Dan Little <theduckylittle at gmail.com
> >     <mailto:theduckylittle at gmail.com> <theduckylittle at gmail.com>>
> >     Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org
> >     <mailto:geomoose-users at lists.osgeo.org> <
> geomoose-users at lists.osgeo.org>>
> >     Subject: [Geomoose-users] Search Capablility For A Layer with
> >     Message-ID: <5321E307.4000509 at agriciencia.com
> >     <mailto:5321E307.4000509 at agriciencia.com> <
> 5321E307.4000509 at agriciencia.com>>
> >     Content-Type: text/plain; charset="iso-8859-1"; Format="flowed"
> >     Yes UTF-8
> >     You can see the interface here although in Portuguese:
> >     http://agriciencia.servehttp.com:1024/riplante/riplante.html
> >     I have also the same issues in the identify tool. If i use a
> shapefile
> >     and read directly from the table stored in a folder it doesnt
> >     work. If i
> >     put them in PostGIS it reads ok and all the special characters are
> >     identified.
> >     Regards
> >     Andr?
> >     Untitled Document
> >     Em 13-03-2014 16:38, Dan Little escreveu:
> >     > Hi Andr?,
> >     > This is an issue with encodings and PHP that I need to work out. I
> >     > keep forgetting to do it. We've ran into this problem with Russian,
> >     > Turkish, and German. I can probably create a test case for German.
> >     > Are you using UTF-8?
> >     > On Wed, Mar 12, 2014 at 1:01 PM, Andr? Barriguinha
> >     > <mailto:andrebarriguinha at agriciencia.com <
> andrebarriguinha at agriciencia.com>>> wrote:
> >     > I'm having trouble setting up the search to a layer when I use
> >     > characters like ? ou ?
> >     > Basicaly writen in Portuguese with some special characters.
> >     > The layer is in a PostGIS database and works fine if I search
> >     > words with no special characters
> >     > Iam using the comparitor like-icase
> >     > Regards
> >     > Andr? Barriguinha
> >     > <http://www.agriciencia.com/> <http://www.agriciencia.com/>
> *Andr? Barriguinha*
> >     > */Agri-Ci?ncia, Consultores de Engenharia, Lda./*
> >     > <http://www.agriciencia.com> <http://www.agriciencia.com>
> >     > Rua dos Lus?adas, 52 - 1?
> >     > 1300-372 LISBOA
> >     > PORTUGAL
> >     > *E-mail: *andrebarriguinha at agriciencia.com
> >     > *Telef: *+(351) 213 649 625
> >     > *Telm:* +(351) 914 155 278 <tel:%2B%28351%29%20914%20155%20278>
> <%2B%28351%29%20914%20155%20278>
> >     > *Fax:* +(351) 213 649 625 <tel:%2B%28351%29%20213%20649%20625>
> <%2B%28351%29%20213%20649%20625>
> >     > _______________________________________________
> >     > Geomoose-users at lists.osgeo.org
> >     <mailto:Geomoose-users at lists.osgeo.org> <
> >     <mailto:Geomoose-users at lists.osgeo.org <
> Geomoose-users at lists.osgeo.org>>
> >     -------------- next part --------------
> >     An HTML attachment was scrubbed...
> >     URL:
> http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.html>
> >     A non-text attachment was scrubbed...
> >     Name: not available
> >     Type: image/jpeg
> >     Desc: not available
> >     URL:
> http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140313/61d0b767/attachment.jpe>
> >     Geomoose-users at lists.osgeo.org <mailto:
> Geomoose-users at lists.osgeo.org> <Geomoose-users at lists.osgeo.org>
> >     End of Geomoose-users Digest, Vol 33, Issue 5
> > Micha? Chmielewskimich.chmielewski at gmail.com <mailto:
> mich.chmielewski at gmail.com> <mich.chmielewski at gmail.com>
> > Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://
> > End of Geomoose-users Digest, Vol 33, Issue 8
> URL: <
> http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140314/5983c87e/attachment-0001.html
> Message: 2
> Date: Fri, 14 Mar 2014 14:29:47 +0000
> From: Andr? Barriguinha <andrebarriguinha at agriciencia.com>
> To: James Klassen <klassen.js at gmail.com>
> Message-ID: <5323125B.7050507 at agriciencia.com>
> Content-Type: text/plain; charset="utf-8"; Format="flowed"
> ISO-8859-1
> But if I change to UTF-8 is the same
> Regards
> Andr?
> Em 14-03-2014 14:08, James Klassen escreveu:
> > <mailto:andrebarriguinha at agriciencia.com>> wrote:
> >     Hi,
> >>     comparitor0      |like-icase|
> >>     dojo.preventCache        |1394788474941|
> >>     fieldname0       |distrito|
> >>     highlight        |true|
> >>     layer0   |caop/caop|
> >>     mode     |search|
> >>     template0        |itemquery|
> >>     value0   |bragan%E7a|
> >     Regards
> >     Andr?
> >     <mailto:geomoose-users-request at lists.osgeo.org> escreveu:
> >>      geomoose-users-request at lists.osgeo.org  <mailto:
> >>      geomoose-users-owner at lists.osgeo.org  <mailto:
> >>     Today's Topics:
> >>     Message: 1
> >>     From: Jim Klassen<klassen.js at gmail.com>  <mailto:
> >>     To:geomoose-users at lists.osgeo.org  <mailto:
> >>     Message-ID:<5321EAE4.2070905 at gmail.com>  <mailto:
> on
> makes
> >>     some sense.
> >>     Any objections?
> >>     [1]http://www.w3schools.com/jsref/jsref_escape.asp
> >>>     Hi Andr?,
> >>>     Service.js
> >>>     into
> >>>     into
> urldecode
> >>>     into
> >>>     into
> >>>     lot of fun ;)
> >>>     good lock
> >>>     chmielix
> >>>     On 13 March 2014 17:55, <geomoose-users-request at lists.osgeo.org <mailto:
> >>>     <mailto:geomoose-users-request at lists.osgeo.org>  <mailto:
> geomoose-users at lists.osgeo.org>  <mailto:geomoose-users at lists.osgeo.org>
> >>>          <mailto:geomoose-users-owner at lists.osgeo.org>  <mailto:
> specific
> >>>          Today's Topics:
> >>>          Message: 1
> >>>          From: Andr? Barriguinha <andrebarriguinha at agriciencia.com <mailto:
> >>>          <mailto:andrebarriguinha at agriciencia.com>  <mailto:
> >>>          To: Dan Little <theduckylittle at gmail.com  <mailto:
> >>>          <mailto:theduckylittle at gmail.com>  <mailto:
> >>>          Cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org <mailto:
> >>>          <mailto:geomoose-users at lists.osgeo.org>  <mailto:
> >>>          Message-ID: <5321E307.4000509 at agriciencia.com  <mailto:
> >>>          <mailto:5321E307.4000509 at agriciencia.com>  <mailto:
> Format="flowed"
> >>>          Yes UTF-8
> shapefile
> >>>          work. If i
> characters are
> >>>          identified.
> >>>          Regards
> >>>          Andr?
> >>>          Untitled Document
> >>>          > Hi Andr?,
> out. I
> Russian,
> German.
> use
> search
> >>>          > Regards
> >>>          > Andr? Barriguinha
>  *Andr? Barriguinha*
> >>>          > 1300-372 LISBOA
> >>>          > PORTUGAL
> >>>          > *E-mail: *andrebarriguinha at agriciencia.com  <mailto:
> >>>          > *Telm:*+(351) 914 155 278
>  <tel:%2B%28351%29%20914%20155%20278>  <tel:%2B%28351%29%20914%20155%20278>
> >>>          > *Fax:*+(351) 213 649 625
>  <tel:%2B%28351%29%20213%20649%20625>  <tel:%2B%28351%29%20213%20649%20625>
> >>>          <mailto:Geomoose-users at lists.osgeo.org>  <mailto:
> >>>          URL:
> >>>          Name: not available
> >>>          Type: image/jpeg
> >>>          Desc: not available
> >>>          URL:
> Geomoose-users at lists.osgeo.org>  <mailto:Geomoose-users at lists.osgeo.org>
> >>>     Micha? Chmielewski
> >>>     mich.chmielewski at gmail.com  <mailto:mich.chmielewski at gmail.com>
>  <mailto:mich.chmielewski at gmail.com>  <mailto:mich.chmielewski at gmail.com>
> URL: <
> http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140314/622938be/attachment.html
> End of Geomoose-users Digest, Vol 33, Issue 10
Michał Chmielewski
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140314/d61c8151/attachment-0001.html>
More information about the Geomoose-users mailing list
