[Geomoose-users] Idintify over Geoserver WFS in GeoMOOSE
Dan Little
theduckylittle at gmail.com
Mon Mar 31 10:43:56 PDT 2014
Identify requires that a layer be served via MapServer at this point.
There is some stubbed out functionality for using WMS (which I think
jklassen or bfraser might be using) but nothing for WFS yet. I should
put it on the to-do list.
On Mon, Mar 31, 2014 at 12:07 PM, <favila at iclam.gov.ve> wrote:
> No errors detected using Firebug. I supposed the problem was the
> <geometry-name>, I removed it and it works now!
> Thank you very much for your help. Now, I will like to use the identify tool
> to show some features of the served polygon. I have not had any success
> doing it!
> If you don't mind....
> THANKS AGAIN.
> De: Dan Little <theduckylittle at gmail.com>
> Para: favila at iclam.gov.ve
> cc: GeoMOOSE Users List <geomoose-users at lists.osgeo.org>
> Fecha: 31/03/2014 09:20
> Asunto: Re: [Geomoose-users] Geoserver WFS in GeoMOOSE
> ________________________________
> Are you testing on Firefox or Chrome? Can you use Firebug or Developer
> Tools to check that the URL GeoMOOSE is calling is returning valid
> WFS/GML?
> On Thu, Mar 20, 2014 at 1:56 PM, <favila at iclam.gov.ve> wrote:
>> I published a WFS in GEOSERVER which I have used several times in QGIS.
>> Now
>> I have been trying to publish it in GeoMOOSE 2.6. I dont want to use WMS
>> because I need to query the NAME among others features of the polygon
>> served.
>> I used this syntaxis in GeoMOOSE mapbook but it did not show any image,
>> polygon or error:
>> <map-source name="lago" type="wfs">
>> <style type="stylemap"><![CDATA[
>> "strokeColor" : "#00ff00",
>> "label" : "${NOMBRE}"
>> ]]></style>
>> <url>http://localhost:8080/geoserver/ows?</url>
>> <attribute name="NOMBRE" type="text" label="Nombre:"/>
>> <feature-namespace>lago</feature-namespace>
>> <feature-type>lago</feature-type>
>> <geometry-name>polygon</geometry-name>
>> <schema>
>> <![CDATA[http://localhost:8080/geoserver/lago/wfs?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=lago:lago]]></schema>
>> </map-source>
>> In the catalog section, the layer is described as:
>> <layer title="Lago de Maracaibo" src="lago" activate="true" fade="false"
>> unfade="false" legend="false"/>
>> Any help is welcome!
>> Fermin
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
