[Geomoose-users] feature_report data sources
R. Paul Warriner
warrinerr at orchardparkny.org
Thu Nov 27 08:38:01 PST 2014
Thank you for the responses Raffaele and Brent.
The layer is good, I have all the features for the layer showing up, and
identify works fine showing appropriate attributes, but when trying to run a
Report or Search Parcels, I get errors from feature_report.php or query.php
respectively.
When I change the mapfile data source from PG to shapefile, the report and
query options work fine, but not under PG.
LAYER
CONNECTIONTYPE postgis
NAME parcels
#DATA './parcels.shp'
CONNECTION "host=xxxx dbname=xxxxx port=xxxx user=xxxxx
password=xxxxx"
DATA "geom from parcel_poly_geomoose"
GROUP parcels_group
STATUS ON
TYPE POLYGON
LABELITEM 'sbl'
LABELCACHE ON
LABELMAXSCALE 20000
# FILTER ([PARC_CODE] == 1)
CLASS
-----Original Message-----
[mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Raffaele
Morelli
Sent: Thursday, November 27, 2014 10:07 AM
To: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] feature_report data sources
On 27/11/14 at 09:40am, R. Paul Warriner wrote:
> Hello,
> New to GeoMoose.
> Can only shapefiles be used for the feature_report, as I am getting
> script errors when switching to a PostGIS layer?
> Regards,
> Paul
Feature_report is mapfile dependent, no matter what datasource you are
using.
And if you are getting errors on a PostGIS layer... there you go.
Check your mapfile with:
shp2img -m path/to/your/mapfile -l layername_here -all_debug 3
see shp2img --help for other debug options
My mama said
to get things done
You'd better not mess
with Major Tom
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
