[Geomoose-users] remove or clear old geocoding placemark
Dan Little
theduckylittle at gmail.com
Wed Oct 8 10:09:45 PDT 2014
I've been working on this again, specifically updating the 2.7 version
for compatibility.
Here's what I've come up with so far:
- https://github.com/geomoose/geomoose/issues/53
Bob, can you send me a more specific link? I think I'm going to need
to backchannel you a fix because I suspect your code is not canonical.
On Fri, Sep 19, 2014 at 12:44 PM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
> Hi again,
> Any more ideas on this? I tried messing with Geomoose.js but was not able to selove the problem.
> -BB
> ________________________________________
> From: Bistrais, Bob
> Sent: Monday, August 04, 2014 10:28 AM
> To: Dan Little
> Cc: geomoose-users at lists.osgeo.org
> Subject: RE: [Geomoose-users] remove or clear old geocoding placemark
> Hitting the clear all button does NOT remove the placemarks. Only refreshing the browser will.
> -----Original Message-----
> From: Dan Little [mailto:theduckylittle at gmail.com]
> Sent: Saturday, August 02, 2014 11:57 AM
> To: Bistrais, Bob
> Subject: Re: [Geomoose-users] remove or clear old geocoding placemark
> Does hitting the "clear all" button remove the placemarks? That would also remove any highlighting but it may be a start to working on a solution.
> If so, we can probably add a line to call an appropriate "clear"
> function in the <script> section of your <results> XML.
> On Wed, Jul 30, 2014 at 2:37 PM, Bistrais, Bob <Bob.Bistrais at maine.gov> wrote:
>> I have noticed a problem with functions that geocode an address.
>> (GeoMoose
>> 2.6)
>> When I find an address, a placemark gets placed on that address.
>> That’s fine, but if I find a second, third, etc, address, the previous
>> placemarks are still on the map. The only way they are removed is by
>> refreshing the browser.
>> How can I get previous placemarks to clear when I geocode a new address?
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
