[Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
TC Haddad
tchaddad at gmail.com
Thu Oct 9 07:31:53 PDT 2014
Another use for this sort of splash Div would be to show content that does
not easily fit in the side bar - sort of like an on-screen feature report,
that contains lots of related information for a feature of interest. You
would click on a feature, the splash screen would load all the goodies from
some sort of report service, and then the whole thing could be closed and
the user would be right back in the map with minimal disruption.
Not everything fits in a map pop-up or side bar panel...
On Thu, Oct 9, 2014 at 10:05 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> Hi Dan,
> Most of the options I read about were suggestions to using a DIV that you
> swap out, which seems straightforward enough. Doesn't seem like it needs
> to be included in the distro though, although, it does start me thinking on
> other things like using the DIV to indicate a presence online of a GeoMoose
> install, stuff like that could be contained in this other outer div
> separate from the main application interface.
> Another random though, I wonder if it couldn't also contain a sort of
> application console of sorts, similar to the stuff you implemented before
> Firebug existed. I know there is the Firebug stuff, but I find myself
> testing on more than one browser these days, and even a simplified resource
> console would help.
> I'll play around with setting something up and see where it goes.
> Thanks
> Bobb
> -----Original Message-----
> From: Dan Little [mailto:theduckylittle at gmail.com]
> Sent: Thursday, October 09, 2014 8:39 AM
> To: Basques, Bob (CI-StPaul)
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] General question related to adding a Splash
> IIRC Brian Fischer and the Houston guys had an extension that did exactly
> that. It's not too hard to do using either HTML/CSS tricks or some
> javascript.
> My long term hopes are always to have the application load fast enough
> that a splash screen isn't necessary.
> On Tue, Oct 7, 2014 at 2:09 PM, Basques, Bob (CI-StPaul) <
> > All,
> > Was wondering about general interest in the ability to add in a Splash
> > screen of some sort to GeoMoose upon startup. Maybe as simple as an
> > image displaying for some amount of time upon page load. Could be an
> > animated thing, GIF or PNG, maybe even SVG. Would fade away to the
> > completely loaded interface once loaded in the background?
> > Thoughts, ideas on the demo splash content.
> > Bobb
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20141009/bf16dd14/attachment.html>
More information about the Geomoose-users
