[Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Thu Oct 9 07:05:29 PDT 2014
Hi Dan,
Most of the options I read about were suggestions to using a DIV that you swap out, which seems straightforward enough. Doesn't seem like it needs to be included in the distro though, although, it does start me thinking on other things like using the DIV to indicate a presence online of a GeoMoose install, stuff like that could be contained in this other outer div separate from the main application interface.
Another random though, I wonder if it couldn't also contain a sort of application console of sorts, similar to the stuff you implemented before Firebug existed. I know there is the Firebug stuff, but I find myself testing on more than one browser these days, and even a simplified resource console would help.
I'll play around with setting something up and see where it goes.
Thanks
Bobb
-----Original Message-----
From: Dan Little [mailto:theduckylittle at gmail.com]
Sent: Thursday, October 09, 2014 8:39 AM
To: Basques, Bob (CI-StPaul)
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
IIRC Brian Fischer and the Houston guys had an extension that did exactly that. It's not too hard to do using either HTML/CSS tricks or some javascript.
My long term hopes are always to have the application load fast enough that a splash screen isn't necessary.
On Tue, Oct 7, 2014 at 2:09 PM, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
> All,
> Was wondering about general interest in the ability to add in a Splash
> screen of some sort to GeoMoose upon startup. Maybe as simple as an
> image displaying for some amount of time upon page load. Could be an
> animated thing, GIF or PNG, maybe even SVG. Would fade away to the
> completely loaded interface once loaded in the background?
> Thoughts, ideas on the demo splash content.
> Bobb
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
