[Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
TC Haddad
tchaddad at gmail.com
Thu Oct 9 08:24:05 PDT 2014
I remembered seeing this sort of div in an old ka-map showing climate data.
The process was:
- Turn on the info tool
- Click or drag on one or several POIs
- Small report shows in the side bar
- Click the "Climate" icon in the small report
- The large report appears in the on-screen splash div
- Navigate between reports in your selection set (if you selected more
than one)
- Close the splash div and return to the map
Personally, I think it has a lot of potential. Here's the link to that map,
for the curious: http://clima.ominiverdi.org/ka-map/htdocs/
T
On Thu, Oct 9, 2014 at 10:36 AM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> Another couple of thoughts, Something like a “Get Info’ option on the
> Mac, where basic installation information might be viewed, even an “About”
> viewer could be included.
> Hmmm . . . .
> Bobb
> *From:* geomoose-users-bounces at lists.osgeo.org [mailto:
> geomoose-users-bounces at lists.osgeo.org] *On Behalf Of *TC Haddad
> *Sent:* Thursday, October 09, 2014 9:32 AM
> *To:* geomoose-users at lists.osgeo.org
> *Subject:* Re: [Geomoose-users] General question related to adding a
> Another use for this sort of splash Div would be to show content that does
> not easily fit in the side bar - sort of like an on-screen feature report,
> that contains lots of related information for a feature of interest. You
> would click on a feature, the splash screen would load all the goodies from
> some sort of report service, and then the whole thing could be closed and
> the user would be right back in the map with minimal disruption.
> Not everything fits in a map pop-up or side bar panel...
> On Thu, Oct 9, 2014 at 10:05 AM, Basques, Bob (CI-StPaul) <
> Hi Dan,
> Most of the options I read about were suggestions to using a DIV that you
> swap out, which seems straightforward enough. Doesn't seem like it needs
> to be included in the distro though, although, it does start me thinking on
> other things like using the DIV to indicate a presence online of a GeoMoose
> install, stuff like that could be contained in this other outer div
> separate from the main application interface.
> Another random though, I wonder if it couldn't also contain a sort of
> application console of sorts, similar to the stuff you implemented before
> Firebug existed. I know there is the Firebug stuff, but I find myself
> testing on more than one browser these days, and even a simplified resource
> console would help.
> I'll play around with setting something up and see where it goes.
> Thanks
> Bobb
> -----Original Message-----
> From: Dan Little [mailto:theduckylittle at gmail.com]
> Sent: Thursday, October 09, 2014 8:39 AM
> To: Basques, Bob (CI-StPaul)
> Cc: geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] General question related to adding a Splash
> IIRC Brian Fischer and the Houston guys had an extension that did exactly
> that. It's not too hard to do using either HTML/CSS tricks or some
> javascript.
> My long term hopes are always to have the application load fast enough
> that a splash screen isn't necessary.
> On Tue, Oct 7, 2014 at 2:09 PM, Basques, Bob (CI-StPaul) <
> > All,
> > Was wondering about general interest in the ability to add in a Splash
> > screen of some sort to GeoMoose upon startup. Maybe as simple as an
> > image displaying for some amount of time upon page load. Could be an
> > animated thing, GIF or PNG, maybe even SVG. Would fade away to the
> > completely loaded interface once loaded in the background?
> > Thoughts, ideas on the demo splash content.
> > Bobb
> > Geomoose-users mailing list
> > Geomoose-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20141009/87b2d40e/attachment-0001.html>
More information about the Geomoose-users
