[Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
Dan Little
theduckylittle at gmail.com
Thu Oct 9 08:40:51 PDT 2014
Whoa.... ka-map....
On Thu, Oct 9, 2014 at 10:24 AM, TC Haddad <tchaddad at gmail.com> wrote:
> I remembered seeing this sort of div in an old ka-map showing climate data.
> The process was:
> Turn on the info tool
> Click or drag on one or several POIs
> Small report shows in the side bar
> Click the "Climate" icon in the small report
> The large report appears in the on-screen splash div
> Navigate between reports in your selection set (if you selected more than
> one)
> Close the splash div and return to the map
> Personally, I think it has a lot of potential. Here's the link to that map,
> for the curious: http://clima.ominiverdi.org/ka-map/htdocs/
> T
> On Thu, Oct 9, 2014 at 10:36 AM, Basques, Bob (CI-StPaul)
> <bob.basques at ci.stpaul.mn.us> wrote:
>> Another couple of thoughts, Something like a “Get Info’ option on the
>> Mac, where basic installation information might be viewed, even an “About”
>> viewer could be included.
>> Hmmm . . . .
>> Bobb
>> From: geomoose-users-bounces at lists.osgeo.org
>> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of TC Haddad
>> Sent: Thursday, October 09, 2014 9:32 AM
>> To: geomoose-users at lists.osgeo.org
>> Subject: Re: [Geomoose-users] General question related to adding a Splash
>> Another use for this sort of splash Div would be to show content that does
>> not easily fit in the side bar - sort of like an on-screen feature report,
>> that contains lots of related information for a feature of interest. You
>> would click on a feature, the splash screen would load all the goodies from
>> some sort of report service, and then the whole thing could be closed and
>> the user would be right back in the map with minimal disruption.
>> Not everything fits in a map pop-up or side bar panel...
>> On Thu, Oct 9, 2014 at 10:05 AM, Basques, Bob (CI-StPaul)
>> Hi Dan,
>> Most of the options I read about were suggestions to using a DIV that you
>> swap out, which seems straightforward enough. Doesn't seem like it needs to
>> be included in the distro though, although, it does start me thinking on
>> other things like using the DIV to indicate a presence online of a GeoMoose
>> install, stuff like that could be contained in this other outer div separate
>> from the main application interface.
>> Another random though, I wonder if it couldn't also contain a sort of
>> application console of sorts, similar to the stuff you implemented before
>> Firebug existed. I know there is the Firebug stuff, but I find myself
>> testing on more than one browser these days, and even a simplified resource
>> console would help.
>> I'll play around with setting something up and see where it goes.
>> Thanks
>> Bobb
>> -----Original Message-----
>> From: Dan Little [mailto:theduckylittle at gmail.com]
>> Sent: Thursday, October 09, 2014 8:39 AM
>> To: Basques, Bob (CI-StPaul)
>> Cc: geomoose-users at lists.osgeo.org
>> IIRC Brian Fischer and the Houston guys had an extension that did exactly
>> that. It's not too hard to do using either HTML/CSS tricks or some
>> javascript.
>> My long term hopes are always to have the application load fast enough
>> that a splash screen isn't necessary.
>> On Tue, Oct 7, 2014 at 2:09 PM, Basques, Bob (CI-StPaul)
>> > All,
>> > Was wondering about general interest in the ability to add in a Splash
>> > screen of some sort to GeoMoose upon startup. Maybe as simple as an
>> > image displaying for some amount of time upon page load. Could be an
>> > animated thing, GIF or PNG, maybe even SVG. Would fade away to the
>> > completely loaded interface once loaded in the background?
>> > Thoughts, ideas on the demo splash content.
>> > Bobb
>> > _______________________________________________
>> > Geomoose-users mailing list
>> > Geomoose-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users
