[Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Thu Oct 9 13:46:41 PDT 2014
I was thinking something more like this:
http://labcase.org/
that ends on the map interface after it's loaded.
This one is kinda nice too:
http://mohamedandali.co/
This one is nice and simple, think about the map in the BG instead of the picture . . .
http://www.schmollcreative.com/
This one is kinda interesting too, starts me thinking on ways to segregate out user settings from the interface, even User docs could be plopped into something like this.  Starts to look like a phone interface too.
http://bluedolphinkauai.com/
nice effect:
http://frii.io/
Just plain old cool looking . . .
http://www.curvadc.com/
and a bunch more . . . .
http://www.dtelepathy.com/
-----Original Message-----
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Eli Adam
Sent: Thursday, October 09, 2014 3:15 PM
To: Dan Little
Cc: geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] General question related to adding a Splash screen to GeoMoose upon startup.
For reference, here is some dated loading graphic details.  You can see this or similar in action here, http://maps.co.crook.or.us/
The following will allow you to add a loading symbol to your maps.
Create the file MapLoading.js with the code below and place it in your htdocs/extensions folder.
    // JavaScript Document
     LoadingExtension = new OpenLayers.Class(GeoMOOSE.UX.Extension, {
   load: function() {
   var loadingpanel = new OpenLayers.Control.LoadingPanel();
   Map.addControl(loadingpanel);
   CLASS_NAME: "LoadingExtension"
    GeoMOOSE.UX.register('LoadingExtension');
    var loadingpanel=new LoadingExtension();
Navigate to the OpenLayers website, download LoadingPanel.js and place it in your htdocs/OpenLayers-2.8/lib/OpenLayers/Control folder.
Add any animated gif loading symbol to your htdocs/skins/myskin/images folder. Here is a cool app that lets you create and download an animated gif link
Add the folowing code to myskin.css:
   .olControlLoadingPanel {
       background-image:url(images/loading.gif);
       position: relative;
       width: 100px;
       height: 100px;
       left: 45%;
       top: 45%;
       background-position:center;
       background-repeat:no-repeat;
       display: none;
Add the following javascript references to geomoose.html:
   <script type="text/javascript"
src="OpenLayers-2.8/lib/OpenLayers/Control/LoadingPanel.js"></script>
   <script type="text/javascript" src="extensions/MapLoading.js"></script>
Eli
On Thu, Oct 9, 2014 at 8:40 AM, Dan Little <theduckylittle at gmail.com> wrote:
> Whoa.... ka-map....
> On Thu, Oct 9, 2014 at 10:24 AM, TC Haddad <tchaddad at gmail.com> wrote:
>> I remembered seeing this sort of div in an old ka-map showing climate data.
>> The process was:
>> Turn on the info tool
>> Click or drag on one or several POIs
>> Small report shows in the side bar
>> Click the "Climate" icon in the small report The large report appears
>> in the on-screen splash div Navigate between reports in your
>> selection set (if you selected more than
>> one)
>> Close the splash div and return to the map
>> Personally, I think it has a lot of potential. Here's the link to
>> that map, for the curious: http://clima.ominiverdi.org/ka-map/htdocs/
>> T
>> On Thu, Oct 9, 2014 at 10:36 AM, Basques, Bob (CI-StPaul)
>> <bob.basques at ci.stpaul.mn.us> wrote:
>>> Another couple of  thoughts,  Something like a “Get Info’ option on
>>> the Mac, where basic installation information might be viewed, even an “About”
>>> viewer could be included.
>>> Hmmm . . . .
>>> Bobb
>>> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of TC
>>> Haddad
>>> Sent: Thursday, October 09, 2014 9:32 AM
>>> To: geomoose-users at lists.osgeo.org
>>> Another use for this sort of splash Div would be to show content
>>> that does not easily fit in the side bar - sort of like an on-screen
>>> feature report, that contains lots of related information for a
>>> feature of interest. You would click on a feature, the splash screen
>>> would load all the goodies from some sort of report service, and
>>> then the whole thing could be closed and the user would be right back in the map with minimal disruption.
>>> Not everything fits in a map pop-up or side bar panel...
>>> On Thu, Oct 9, 2014 at 10:05 AM, Basques, Bob (CI-StPaul)
>>> Hi Dan,
>>> Most of the options I read about were suggestions to using a DIV
>>> that you swap out, which seems straightforward enough.  Doesn't seem
>>> like it needs to be included in the distro though, although, it does
>>> start me thinking on other things like using the DIV to indicate a
>>> presence online of a GeoMoose install, stuff like that could be
>>> contained in this other outer div separate from the main application interface.
>>> Another random though, I wonder if it couldn't also contain a sort
>>> of application console of sorts, similar to the stuff you
>>> implemented before Firebug existed.  I know there is the Firebug
>>> stuff, but I find myself testing on more than one browser these
>>> days, and even a simplified resource console would help.
>>> I'll play around with setting something up and see where it goes.
>>> Thanks
>>> Bobb
>>> From: Dan Little [mailto:theduckylittle at gmail.com]
>>> Sent: Thursday, October 09, 2014 8:39 AM
>>> To: Basques, Bob (CI-StPaul)
>>> IIRC Brian Fischer and the Houston guys had an extension that did
>>> exactly that.  It's not too hard to do using either HTML/CSS tricks
>>> or some javascript.
>>> My long term hopes are always to have the application load fast
>>> enough that a splash screen isn't necessary.
>>> On Tue, Oct 7, 2014 at 2:09 PM, Basques, Bob (CI-StPaul)
>>> > All,
>>> > Was wondering about general interest in the ability to add in a
>>> > Splash screen of some sort to GeoMoose upon startup.  Maybe as
>>> > simple as an image displaying for some amount of time upon page
>>> > load.  Could be an animated thing, GIF or PNG, maybe even SVG.
>>> > Would fade away to the completely loaded interface once loaded in the background?
>>> > Thoughts, ideas on the demo splash content.
>>> > Bobb
>>> > _______________________________________________
>>> > Geomoose-users mailing list
>>> > Geomoose-users at lists.osgeo.org
>>> > http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
