[Geomoose-users] USGS NationalMap WMS Error
Jim Klassen klassen.js at gmail.com
Wed Oct 22 12:16:31 PDT 2014
Ok, now am I even more confused as it has started working again.  It
looks like VERSION=1.1.1 was being added already by GeoMoose.  Since I
didn't change anything, I can only figure there must have been problems
on the far end.
(For clarification OSGeo MapServer is not involved at all, this is
direct to the USGS servers from GeoMoose).
On 10/22/2014 01:45 PM, TC Haddad wrote:
> Ummm... this is just a long shot, but it looks like by default, this is a
> WMS 1.3.0, not WMS 1.1.1
> In WMS 1.3.0, you have to use CRS=EPSG:3857 instead of SRS=EPSG:3857 in the
> URL.
> It does look like the service also supports WMS 1.1.1, so I would try
> adding the version to your URL fragment, to force the version you want to
> use, and see if it makes the server happy with using SRS=EPSG:3857
> like so:
> http://basemap.
> <http://basemap.nationalmap.gov/ArcGIS/services/USGSImageryOnly/MapServer/WMSServer?version=1.1.1&>
> Mapserver should take care of the rest of the differences between 1.3.0 and
> 1.1.1.
> Tanya
> On Wed, Oct 22, 2014 at 11:08 AM, Jim Klassen <klassen.js at gmail.com> wrote:
>> I am having difficulty connecting GeoMoose to the NationalMap's imagery
>> service.
>> The GetMap response says invalid SRS.  It appears GeoMoose is sending
>> SRS=EPSG%3A3857 and the service is expecting SRS=EPSG:3857.  This used
>> to work a while ago. I am not sure what changed.  I've tried with
>> GeoMoose 2.6.1 through master.
>> Any thoughts what I might be doing wrong?
>> Mapbook fragment:
>>     <map-source name='tnm_usgsimagery' type="wms" tiled="false"
>> opacity="1.0">
>>         <param name="TRANSPARENT" value="false"/>
>>         <param name="FORMAT" value="image/jpeg"/>
>> <url>
>> ?</url>
>>         <layer name="0"/>
>>     </map-source>
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
