[Geomoose-users] Identify Tolerance
Clinton Olsen
clintono at emery.utah.gov
Fri Sep 5 09:27:45 PDT 2014
I used a ESRI program to reproject the layer to web mercator, so Geomoose
isn't doing any reprojecting.
I took the advice to set my TOLERANCE to 3 and the TOLERANCEUNITS to pixels
and I still don't have any result other than the coordinates.
I ran Geomoose through the Internet Explorer F12 network tool and when I
try an identify it seems to send its data through
/geomoose2/php/idenitfy.php, with a POST method and 200 for the Result.
Thanks for the suggestions so far. Any other ideas as to what I could try?
LAYER
NAME "boulders"
DATA "boulders.shp"
STATUS DEFAULT
TYPE POINT
METADATA
# drill-down identify service record.
'identify_record' 'identify_boulders.html'
END
TOLERANCE 3
TOLERANCEUNITS pixels
LABELITEM 'BOULDER'
LABELCACHE ON
LABELMAXSCALE 100000
CLASS
NAME 'Boulders'
STYLE
SYMBOL 'CIRCLE'
COLOR 255 102 51
OUTLINECOLOR 0 0 0
SIZE 8
END
LABEL
TYPE TRUETYPE
FONT vera_sans-bold
SIZE 8
ANTIALIAS TRUE
COLOR 0 0 0
OUTLINECOLOR 254 254 254
BUFFER 4
PARTIALS FALSE
POSITION auto
SIZE 7
END #end label
END#end class
END#end layer
END #end map
On Wed, Sep 3, 2014 at 10:47 AM, Anderson, Dean <anderson.dean at co.polk.or.us
> wrote:
> That sounds better to me. Especially when you have different projections.
> On Wed, Sep 3, 2014 at 9:21 AM, Brent Fraser <bfraser at geoanalytic.com>
> wrote:
>> Clinton,
>> I like using
>> TOLERANCE 3
>> TOLERANCEUNITS PIXELS
>> to make it more "zoom friendly".
>> And you can use the debugging tool (F12, Network tab, Response sub-tab)
>> on your browser to view the conversation between browser and the server.
>> Best Regards,
>> Brent Fraser
>> On 9/3/2014 9:20 AM, Clinton Olsen wrote:
>> Dean,
>> I adjusted my map file according to your suggestions and I still am not
>> retrieving any information from the point layer. I don't know if this will
>> help but I have all of my layers reprojected to the web mercator projection
>> (EPSG:3857). Is there a way to see if anything is being passed when I try
>> to identify an object? Below is my mapfile with the suggested changes.
>> LAYER
>> NAME "boulders"
>> DATA "boulders.shp"
>> STATUS DEFAULT
>> TYPE POINT
>> METADATA
>> END
>> TOLERANCE 100
>> TOLERANCEUNITS meters
>> LABELITEM 'BOULDER'
>> LABELCACHE ON
>> CLASS
>> NAME 'Boulders'
>> STYLE
>> SYMBOL 'CIRCLE'
>> COLOR 255 102 51
>> OUTLINECOLOR 0 0 0
>> SIZE 8
>> END
>> LABEL
>> TYPE TRUETYPE
>> FONT vera_sans-bold
>> SIZE 8
>> ANTIALIAS TRUE
>> COLOR 0 0 0
>> BUFFER 4
>> PARTIALS FALSE
>> POSITION auto
>> SIZE 7
>> END #end label
>> END#end class
>> On Fri, Aug 29, 2014 at 4:15 PM, Anderson, Dean <
>> anderson.dean at co.polk.or.us> wrote:
>>> Here is what I use to identify roads and the tolerances seems to work
>>> fine. (TOLERANCE 100
>>> TOLERANCEUNITS FEET) as follows:
>>> Layer #14
>>> Name "Roads"
>>> Data './data/RoadAllWeb'
>>> Status On
>>> Type Line
>>> METADATA
>>> 'identify_record' 'templates/identify_road.html'
>>> END
>>> TOLERANCE 100
>>> TOLERANCEUNITS FEET
>>> ClassItem "RoadType"
>>> Class
>>> Name "Major Roads"
>>> minscale 40001
>>> maxscale 100000
>>> EXPRESSION "Major Roads"
>>> STYLE
>>> Width 4
>>> COLOR 168 112 0
>>> END
>>> STYLE
>>> width 2
>>> COLOR 255 211 127
>>> END
>>> End
>>> Class
>>> Name "Major Roads"
>>> maxscale 40000
>>> Minscale 10001
>>> STYLE
>>> width 4
>>> COLOR 168 112 0
>>> END
>>> STYLE
>>> width 2
>>> COLOR 255 211 127
>>> END
>>> End
>>> Class
>>> Name "Major Roads"
>>> maxscale 10000
>>> STYLE
>>> width 6
>>> COLOR 168 112 0
>>> END
>>> STYLE
>>> width 3
>>> COLOR 255 211 127
>>> END
>>> End
>>> Class
>>> Name "Standard Roads"
>>> EXPRESSION "Local Roads"
>>> minscale 40001
>>> maxscale 100000
>>> STYLE
>>> width 2
>>> COLOR 160 160 160
>>> END
>>> STYLE
>>> width 1
>>> COLOR 204 204 204
>>> END
>>> End
>>> Class
>>> maxscale 40000
>>> minscale 10001
>>> STYLE
>>> width 4
>>> COLOR 160 160 160
>>> END
>>> STYLE
>>> width 2
>>> COLOR 204 204 204
>>> END
>>> End
>>> Class
>>> maxscale 10000
>>> STYLE
>>> width 6
>>> COLOR 160 160 160
>>> END
>>> STYLE
>>> width 3
>>> COLOR 204 204 204
>>> END
>>> End
>>> End
>>> On Fri, Aug 29, 2014 at 1:44 PM, Clinton Olsen <clintono at emery.utah.gov
>>> > wrote:
>>>> When I try to identify a line or a point I get coordinates on the
>>>> left side of the template. Is there a way to troubleshoot the identify
>>>> tool? I know I might not have the tolerance set right but how can I figure
>>>> out what the tolerance should be. I have tolerance numbers I have used
>>>> range from 0 - 100. I have tried meters, feet, pixels. I referenced the
>>>> how to setup identify on the geomoose.org site and I got one of my
>>>> polygon layers to work. My template and mapfile are listed below. How can
>>>> I troubleshoot what is wrong with these files?
>>>> <!-- MapServer Template -->
>>>> <tr><td colspan="2"><b>Boulder Areas</b></td></tr>
>>>> <tr><td>Boulder Area: [SECTION]</td></tr>
>>>> <tr><td>Boulder: [BOULDER]</td></tr>
>>>> <tr><td>LAT: [LAT]</td></tr>
>>>> <tr><td>LONG: [LONG]</td></tr>
>>>> <tr><hr></td></tr>
>>>> MAP
>>>> NAME 'BOULDERS'
>>>> SIZE 800 650
>>>> STATUS ON
>>>> EXTENT -12381838.298411 4760938.642311 -12327375.283263
>>>> 4806362.074758
>>>> UNITS METERS
>>>> INCLUDE "../../geomoose_globals.map"
>>>> WEB
>>>> METADATA
>>>> 'ows_title' 'Boulders'
>>>> 'ows_srs' 'EPSG:3857'
>>>> 'ows_enable_request' '*'
>>>> 'ows_onlineresource' 'http://www.geomoose.org'
>>>> END
>>>> END
>>>> PROJECTION
>>>> 'init=EPSG:3857'
>>>> END
>>>> LEGEND
>>>> STATUS ON
>>>> LABEL
>>>> TYPE TRUETYPE
>>>> FONT vera_sans
>>>> SIZE 8
>>>> COLOR 0 0 0
>>>> END
>>>> END
>>>> LAYER
>>>> NAME "boulders"
>>>> DATA "boulders.shp"
>>>> STATUS DEFAULT
>>>> TYPE POINT
>>>> TOLERANCE 0
>>>> LABELITEM 'BOULDER'
>>>> LABELCACHE ON
>>>> CLASS
>>>> NAME 'Boulders'
>>>> STYLE
>>>> SYMBOL 'CIRCLE'
>>>> COLOR 255 102 51
>>>> OUTLINECOLOR 0 0 0
>>>> SIZE 8
>>>> END
>>>> LABEL
>>>> TYPE TRUETYPE
>>>> FONT vera_sans-bold
>>>> SIZE 8
>>>> ANTIALIAS TRUE
>>>> COLOR 0 0 0
>>>> BUFFER 4
>>>> PARTIALS FALSE
>>>> POSITION auto
>>>> SIZE 7
>>>> END
>>>> END
>>>> METADATA
>>>> END
>>>> TOLERANCE 0
>>>> END
>>>> END
>>>> Clinton Olsen
>>>> IS/GIS Technician
>>>> _______________________________________________
>>>> Geomoose-users mailing list
>>>> Geomoose-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>> Dean R Anderson
>>> IT Director
>>> Polk County
>> *Please note my email address has changed to clintono at emery.utah.gov.
>> Please update your records. Thanks.
>> Clinton Olsen
>> *EMERY COUNTY*
>> IS/GIS Technician
>> 435-381-3592
>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
> Dean R Anderson
> IT Director
> Polk County
Clinton Olsen
*EMERY COUNTY*
IS/GIS Technician
435-381-3592
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140905/1ea11bf5/attachment-0001.html>
More information about the Geomoose-users
