[Geomoose-users] Identify Tolerance
Brent Fraser bfraser at geoanalytic.com
Fri Sep 5 10:18:53 PDT 2014
Clinton,
if you double click on the "/geomoose2/php/idenitfy.php" entry in the
Internet Explorer debugger, then click on the "Response Body" tab, it
should show you what was sent from the server.  It should look something
like (I'm using the Geomoose demo at http://demo.geomoose.org/master/):
<results>
<script> GeoMOOSE.clearLayerParameters('highlight');
GeoMOOSE.turnLayerOff('highlight/highlight');</script>
<html><![CDATA[<!-- MapServer Template -->
Detailed information for the area you clicked on the map...
<table border="0">
<tr>
<td colspan="2"><b><u>Ground Coordinates</u></b>
<br>
<b>X: </b>486432.0118221
<br>
<b>Y: </b>4939167.527998</td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
</table>
<table border="0" cellpadding="1" cellspacing="2">
<tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
<tr>
<td align="right"><b>PIN:</b></td>
<td>037- <a href="javascript:GeoMOOSE.startService('feature_report',
{'PIN' : '037-', 'src' : 'parcels/parcels'})">Report</a></td>
</tr>
<tr>
<td align="right"><b>Owner Name:</b></td>
<td>Andera Harris</td>
</tr>
<tr>
<td align="right"><b>Est. Market Value:</b></td>
<td>0</td>
</tr>
<tr>
<td align="right"><b>Acres:</b></td>
<td>159.90</td>
</tr>
<tr>
<td> </td>
<td> </td>
</tr>
]]></html><footer><![CDATA[<b>Disclaimer: This information is being
distributed as demonstation data only.  You should not use the data for
any other purposes.</b>
]]></footer>
</results>
Best Regards,
Brent Fraser
On 9/5/2014 10:27 AM, Clinton Olsen wrote:
> I used a ESRI program to reproject the layer to web mercator, so
> Geomoose isn't doing any reprojecting.
> I took the advice to set my TOLERANCE to 3 and the TOLERANCEUNITS to
> pixels and I still don't have any result other than the coordinates.
> I ran Geomoose through the Internet Explorer F12 network tool and when
> I try an identify it seems to send its data through
> /geomoose2/php/idenitfy.php, with a POST method and 200 for the Result.
> Thanks for the suggestions so far.  Any other ideas as to what I could
> try?
> LAYER
>      NAME "boulders"
>      DATA "boulders.shp"
>  STATUS DEFAULT
>      TYPE POINT
>  METADATA
> # drill-down identify service record.
> 'identify_record''identify_boulders.html'
> END
>  TOLERANCE 3
>  TOLERANCEUNITS pixels
> LABELITEM 'BOULDER'
>  LABELCACHE ON
>  LABELMAXSCALE 100000
>          CLASS
> NAME 'Boulders'
>  STYLE
> SYMBOL 'CIRCLE'
> COLOR 255 102 51
> OUTLINECOLOR 0 0 0
> SIZE 8
>          END
> LABEL
>      TYPE TRUETYPE
>      FONT vera_sans-bold
>      SIZE 8
>  ANTIALIAS TRUE
> COLOR 0 0 0
>  OUTLINECOLOR 254 254 254
>      BUFFER 4
>  PARTIALS FALSE
>  POSITION auto
> SIZE7
> END #end label
>   END#end class
> END#end layer
> END #end map
> On Wed, Sep 3, 2014 at 10:47 AM, Anderson, Dean
> <anderson.dean at co.polk.or.us <mailto:anderson.dean at co.polk.or.us>> wrote:
>     That sounds better to me. Especially when you have different
>     projections.
>     On Wed, Sep 3, 2014 at 9:21 AM, Brent Fraser
>     <bfraser at geoanalytic.com <mailto:bfraser at geoanalytic.com>> wrote:
>         Clinton,
>         I like using
>                 TOLERANCE 3
>                 TOLERANCEUNITS PIXELS
>         to make it more "zoom friendly".
>         And you can use the debugging tool (F12, Network tab, Response
>         sub-tab) on your browser to view the conversation between
>         browser and the server.
>         Best Regards,
>         Brent Fraser
>         On 9/3/2014 9:20 AM, Clinton Olsen wrote:
>>         Dean,
>>         I adjusted my map file according to your suggestions and I
>>         still am not retrieving any information from the point layer.
>>          I don't know if this will help but I have all of my layers
>>         reprojected to the web mercator projection (EPSG:3857).  Is
>>         there a way to see if anything is being passed when I try to
>>         identify an object?  Below is my mapfile with the suggested
>>         changes.
>>         LAYER
>>         NAME "boulders"
>>         DATA "boulders.shp"
>>         STATUS DEFAULT
>>         TYPE POINT
>>         METADATA
>>         END
>>         TOLERANCE 100
>>         TOLERANCEUNITS meters
>>         LABELITEM 'BOULDER'
>>         LABELCACHE ON
>>         CLASS
>>         NAME 'Boulders'
>>         STYLE
>>         SYMBOL 'CIRCLE'
>>         COLOR 255 102 51
>>         OUTLINECOLOR 0 0 0
>>                SIZE 8
>>         END
>>         LABEL
>>         TYPE       TRUETYPE
>>         FONT vera_sans-bold
>>         SIZE 8
>>         ANTIALIAS TRUE
>>         COLOR 0 0 0
>>         BUFFER 4
>>         PARTIALS FALSE
>>         POSITION auto
>>         SIZE7
>>         END #end label
>>         END#end class
>>         On Fri, Aug 29, 2014 at 4:15 PM, Anderson, Dean
>>             Here is what I use to identify roads and the tolerances
>>             seems to work fine.  (TOLERANCE 100
>>               TOLERANCEUNITS FEET)  as follows:
>>             Layer  #14
>>               Name "Roads"
>>               Data './data/RoadAllWeb'
>>               Status On
>>               Type Line
>>               METADATA
>>             'identify_record''templates/identify_road.html'
>>               END
>>               TOLERANCE 100
>>               TOLERANCEUNITS FEET
>>               ClassItem "RoadType"
>>             Class
>>                Name "Major Roads"
>>                minscale 40001
>>                maxscale 100000
>>                EXPRESSION "Major Roads"
>>             STYLE
>>             Width 4
>>             COLOR 168 112 0
>>             END
>>             STYLE
>>             width 2
>>             COLOR 255 211 127
>>             END
>>               End
>>               Class
>>                Name "Major Roads"
>>                maxscale 40000
>>                Minscale 10001
>>             STYLE
>>             width 4
>>             COLOR 168 112 0
>>             END
>>             STYLE
>>             width 2
>>             COLOR 255 211 127
>>             END
>>               End
>>               Class
>>                Name "Major Roads"
>>                maxscale 10000
>>             STYLE
>>             width 6
>>             COLOR 168 112 0
>>             END
>>             STYLE
>>             width 3
>>             COLOR 255 211 127
>>             END
>>               End
>>               Class
>>                Name "Standard Roads"
>>                EXPRESSION "Local Roads"
>>                minscale 40001
>>                maxscale 100000
>>             STYLE
>>             width 2
>>             COLOR 160 160 160
>>             END
>>             STYLE
>>             width 1
>>             COLOR 204 204 204
>>             END
>>               End
>>               Class
>>                maxscale 40000
>>                minscale 10001
>>             STYLE
>>             width 4
>>             COLOR 160 160 160
>>             END
>>             STYLE
>>             width 2
>>             COLOR 204 204 204
>>             END
>>               End
>>               Class
>>                maxscale 10000
>>             STYLE
>>             width 6
>>             COLOR 160 160 160
>>             END
>>             STYLE
>>             width 3
>>             COLOR 204 204 204
>>             END
>>               End
>>             End
>>             On Fri, Aug 29, 2014 at 1:44 PM, Clinton Olsen
>>             <clintono at emery.utah.gov
>>             <mailto:clintono at emery.utah.gov>> wrote:
>>                 When I try to identify a line or a point I get
>>                 coordinates on the left side of the template.  Is
>>                 there a way to troubleshoot the identify tool?  I
>>                 know I might not have the tolerance set right but how
>>                 can I figure out what the tolerance should be.  I
>>                 have tolerance numbers I have used range from 0 -
>>                 100.  I have tried meters, feet, pixels.  I
>>                 referenced the how to setup identify on the
>>                 geomoose.org <http://geomoose.org> site and I got one
>>                 of my polygon layers to work.  My template and
>>                 mapfile are listed below.  How can I troubleshoot
>>                 what is wrong with these files?
>>                 <tr><td colspan="2"><b>Boulder Areas</b></td></tr>
>>                 <tr><td>Boulder Area: [SECTION]</td></tr>
>>                 <tr><td>Boulder: [BOULDER]</td></tr>
>>                 <tr><td>LAT: [LAT]</td></tr>
>>                 <tr><td>LONG: [LONG]</td></tr>
>>                 <tr><hr></td></tr>
>>                 MAP
>>                 NAME 'BOULDERS'
>>                 SIZE 800 650
>>                 STATUS ON
>>                 EXTENT  -12381838.298411 4760938.642311
>>                 -12327375.283263 4806362.074758
>>                 UNITS METERS
>>                 INCLUDE "../../geomoose_globals.map"
>>                 WEB
>>                 METADATA
>>                 'ows_title' 'Boulders'
>>                 'ows_srs' 'EPSG:3857'
>>                 'ows_enable_request' '*'
>>                 'ows_onlineresource' 'http://www.geomoose.org'
>>                 END
>>                 END
>>                 PROJECTION
>>                 'init=EPSG:3857'
>>                 END
>>                 LEGEND
>>                      STATUS ON
>>                      LABEL
>>                 TYPE TRUETYPE
>>                 FONT vera_sans
>>                 SIZE 8
>>                 COLOR 0 0 0
>>                      END
>>                 END
>>                 LAYER
>>                      NAME "boulders"
>>                      DATA "boulders.shp"
>>                      STATUS DEFAULT
>>                      TYPE POINT
>>                  TOLERANCE 0
>>                 LABELITEM 'BOULDER'
>>                  LABELCACHE ON
>>                             CLASS
>>                 NAME 'Boulders'
>>                 STYLE
>>                 SYMBOL 'CIRCLE'
>>                 COLOR 255 102 51
>>                 OUTLINECOLOR 0 0 0
>>                 SIZE 8
>>                 END
>>                 LABEL
>>                 TYPE TRUETYPE
>>                 FONT vera_sans-bold
>>                 SIZE 8
>>                 ANTIALIAS TRUE
>>                 COLOR 0 0 0
>>                 BUFFER 4
>>                 PARTIALS FALSE
>>                 POSITION auto
>>                 SIZE7
>>                       END
>>                      END
>>                 METADATA
>>                 END
>>                 TOLERANCE 0
>>                 END
>>                 END
>>                 Clinton Olsen
>>                 IS/GIS Technician
>>                 _______________________________________________
>>                 Geomoose-users mailing list
>>                 Geomoose-users at lists.osgeo.org
>>                 <mailto:Geomoose-users at lists.osgeo.org>
>>                 http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>             Dean R Anderson
>>             IT Director
>>             Polk County
>>         *Please note my email address has changed to
>>         clintono at emery.utah.gov <mailto:clintono at emery.utah.gov>.
>>          Please update your records.  Thanks.
>>         Clinton Olsen
>>         *EMERY COUNTY*
>>         IS/GIS Technician
>>         435-381-3592 <tel:435-381-3592>
>>         Geomoose-users at lists.osgeo.org  <mailto:Geomoose-users at lists.osgeo.org>
>     Dean R Anderson
>     IT Director
>     Polk County
> *Please note my email address has changed to clintono at emery.utah.gov
> <mailto:clintono at emery.utah.gov>.  Please update your records.  Thanks.
> Clinton Olsen
> *EMERY COUNTY*
> IS/GIS Technician
> 435-381-3592
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140905/14f4d48e/attachment-0001.html>
More information about the Geomoose-users mailing list
