[Geomoose-users] Identify Tolerance
Clinton Olsen
clintono at emery.utah.gov
Fri Sep 5 13:33:00 PDT 2014
Brent,
When I try to identify my point layer and check on the Response Body under
the F12 network tab. My the page is blank with no data to view.
I also have two polygon layers that have the identify feature working
correctly. And when I checked their Response Body after identifying it is
blank and says no data to view.
The geomoose demo on the link you sent to me give a response back from the
server, but mine are not giving responses even though some of the layers
still post back identify results.
I changed my tolerance to 50 and got the same result. I tried tolerance
500 and got the same result. I double checked the other suggestions from
TC Haddad, and still no change.
On Fri, Sep 5, 2014 at 11:18 AM, Brent Fraser <bfraser at geoanalytic.com>
wrote:
> Clinton,
> if you double click on the "/geomoose2/php/idenitfy.php" entry in the
> Internet Explorer debugger, then click on the "Response Body" tab, it
> should show you what was sent from the server. It should look something
> like (I'm using the Geomoose demo at http://demo.geomoose.org/master/):
> <results>
> <script> GeoMOOSE.clearLayerParameters('highlight');
> GeoMOOSE.turnLayerOff('highlight/highlight');</script>
> <html><![CDATA[<!-- MapServer Template -->
> Detailed information for the area you clicked on the map...
> <table border="0">
> <tr>
> <td colspan="2"><b><u>Ground Coordinates</u></b>
> <br>
> <b>X: </b>486432.0118221
> <br>
> <b>Y: </b>4939167.527998</td>
> </tr>
> <tr>
> <td> </td>
> <td> </td>
> </tr>
> </table>
> <table border="0" cellpadding="1" cellspacing="2">
> <tr bgcolor="#DEE5EB"><td colspan="2"><b><u>Parcels</u></b></tr>
> <tr>
> <td align="right"><b>PIN:</b></td>
> <td>037- <a href="javascript:GeoMOOSE.startService('feature_report',
> {'PIN' : '037-', 'src' : 'parcels/parcels'})">Report</a></td>
> </tr>
> <tr>
> <td align="right"><b>Owner Name:</b></td>
> <td>Andera Harris</td>
> </tr>
> <tr>
> <td align="right"><b>Est. Market Value:</b></td>
> <td>0</td>
> </tr>
> <tr>
> <td align="right"><b>Acres:</b></td>
> <td>159.90</td>
> </tr>
> <tr>
> <td> </td>
> <td> </td>
> </tr>
> ]]></html><footer><![CDATA[<b>Disclaimer: This information is being
> distributed as demonstation data only. You should not use the data for any
> other purposes.</b>
> ]]></footer>
> </results>
> Best Regards,
> Brent Fraser
> On 9/5/2014 10:27 AM, Clinton Olsen wrote:
> I used a ESRI program to reproject the layer to web mercator, so Geomoose
> isn't doing any reprojecting.
> I took the advice to set my TOLERANCE to 3 and the TOLERANCEUNITS to
> pixels and I still don't have any result other than the coordinates.
> I ran Geomoose through the Internet Explorer F12 network tool and when I
> try an identify it seems to send its data through
> /geomoose2/php/idenitfy.php, with a POST method and 200 for the Result.
> Thanks for the suggestions so far. Any other ideas as to what I could
> try?
> LAYER
> NAME "boulders"
> DATA "boulders.shp"
> STATUS DEFAULT
> TYPE POINT
> METADATA
> # drill-down identify service record.
> 'identify_record' 'identify_boulders.html'
> END
> TOLERANCE 3
> TOLERANCEUNITS pixels
> LABELITEM 'BOULDER'
> LABELCACHE ON
> LABELMAXSCALE 100000
> CLASS
> NAME 'Boulders'
> STYLE
> SYMBOL 'CIRCLE'
> COLOR 255 102 51
> OUTLINECOLOR 0 0 0
> SIZE 8
> END
> LABEL
> TYPE TRUETYPE
> FONT vera_sans-bold
> SIZE 8
> ANTIALIAS TRUE
> COLOR 0 0 0
> OUTLINECOLOR 254 254 254
> BUFFER 4
> PARTIALS FALSE
> POSITION auto
> SIZE 7
> END #end label
> END#end class
> END#end layer
> END #end map
> On Wed, Sep 3, 2014 at 10:47 AM, Anderson, Dean <
> anderson.dean at co.polk.or.us> wrote:
>> That sounds better to me. Especially when you have different projections.
>> On Wed, Sep 3, 2014 at 9:21 AM, Brent Fraser <bfraser at geoanalytic.com>
>> wrote:
>>> Clinton,
>>> I like using
>>> TOLERANCE 3
>>> TOLERANCEUNITS PIXELS
>>> to make it more "zoom friendly".
>>> And you can use the debugging tool (F12, Network tab, Response sub-tab)
>>> on your browser to view the conversation between browser and the server.
>>> Best Regards,
>>> Brent Fraser
>>> On 9/3/2014 9:20 AM, Clinton Olsen wrote:
>>> Dean,
>>> I adjusted my map file according to your suggestions and I still am
>>> not retrieving any information from the point layer. I don't know if this
>>> will help but I have all of my layers reprojected to the web mercator
>>> projection (EPSG:3857). Is there a way to see if anything is being passed
>>> when I try to identify an object? Below is my mapfile with the suggested
>>> changes.
>>> LAYER
>>> NAME "boulders"
>>> DATA "boulders.shp"
>>> STATUS DEFAULT
>>> TYPE POINT
>>> METADATA
>>> END
>>> TOLERANCE 100
>>> TOLERANCEUNITS meters
>>> LABELITEM 'BOULDER'
>>> LABELCACHE ON
>>> CLASS
>>> NAME 'Boulders'
>>> STYLE
>>> SYMBOL 'CIRCLE'
>>> COLOR 255 102 51
>>> OUTLINECOLOR 0 0 0
>>> SIZE 8
>>> END
>>> LABEL
>>> TYPE TRUETYPE
>>> FONT vera_sans-bold
>>> SIZE 8
>>> ANTIALIAS TRUE
>>> COLOR 0 0 0
>>> BUFFER 4
>>> PARTIALS FALSE
>>> POSITION auto
>>> SIZE 7
>>> END #end label
>>> END#end class
>>> On Fri, Aug 29, 2014 at 4:15 PM, Anderson, Dean <
>>>> Here is what I use to identify roads and the tolerances seems to work
>>>> fine. (TOLERANCE 100
>>>> TOLERANCEUNITS FEET) as follows:
>>>> Layer #14
>>>> Name "Roads"
>>>> Data './data/RoadAllWeb'
>>>> Status On
>>>> Type Line
>>>> METADATA
>>>> 'identify_record' 'templates/identify_road.html'
>>>> END
>>>> TOLERANCE 100
>>>> TOLERANCEUNITS FEET
>>>> ClassItem "RoadType"
>>>> Class
>>>> Name "Major Roads"
>>>> minscale 40001
>>>> maxscale 100000
>>>> EXPRESSION "Major Roads"
>>>> STYLE
>>>> Width 4
>>>> COLOR 168 112 0
>>>> END
>>>> STYLE
>>>> width 2
>>>> COLOR 255 211 127
>>>> END
>>>> End
>>>> Class
>>>> Name "Major Roads"
>>>> maxscale 40000
>>>> Minscale 10001
>>>> STYLE
>>>> width 4
>>>> COLOR 168 112 0
>>>> END
>>>> STYLE
>>>> width 2
>>>> COLOR 255 211 127
>>>> END
>>>> End
>>>> Class
>>>> Name "Major Roads"
>>>> maxscale 10000
>>>> STYLE
>>>> width 6
>>>> COLOR 168 112 0
>>>> END
>>>> STYLE
>>>> width 3
>>>> COLOR 255 211 127
>>>> END
>>>> End
>>>> Class
>>>> Name "Standard Roads"
>>>> EXPRESSION "Local Roads"
>>>> minscale 40001
>>>> maxscale 100000
>>>> STYLE
>>>> width 2
>>>> COLOR 160 160 160
>>>> END
>>>> STYLE
>>>> width 1
>>>> COLOR 204 204 204
>>>> END
>>>> End
>>>> Class
>>>> maxscale 40000
>>>> minscale 10001
>>>> STYLE
>>>> width 4
>>>> COLOR 160 160 160
>>>> END
>>>> STYLE
>>>> width 2
>>>> COLOR 204 204 204
>>>> END
>>>> End
>>>> Class
>>>> maxscale 10000
>>>> STYLE
>>>> width 6
>>>> COLOR 160 160 160
>>>> END
>>>> STYLE
>>>> width 3
>>>> COLOR 204 204 204
>>>> END
>>>> End
>>>> End
>>>> On Fri, Aug 29, 2014 at 1:44 PM, Clinton Olsen <
>>>> clintono at emery.utah.gov> wrote:
>>>>> When I try to identify a line or a point I get coordinates on the
>>>>> left side of the template. Is there a way to troubleshoot the identify
>>>>> tool? I know I might not have the tolerance set right but how can I figure
>>>>> out what the tolerance should be. I have tolerance numbers I have used
>>>>> range from 0 - 100. I have tried meters, feet, pixels. I referenced the
>>>>> how to setup identify on the geomoose.org site and I got one of my
>>>>> polygon layers to work. My template and mapfile are listed below. How can
>>>>> I troubleshoot what is wrong with these files?
>>>>> <tr><td colspan="2"><b>Boulder Areas</b></td></tr>
>>>>> <tr><td>Boulder Area: [SECTION]</td></tr>
>>>>> <tr><td>Boulder: [BOULDER]</td></tr>
>>>>> <tr><td>LAT: [LAT]</td></tr>
>>>>> <tr><td>LONG: [LONG]</td></tr>
>>>>> <tr><hr></td></tr>
>>>>> MAP
>>>>> NAME 'BOULDERS'
>>>>> SIZE 800 650
>>>>> STATUS ON
>>>>> EXTENT -12381838.298411 4760938.642311 -12327375.283263
>>>>> 4806362.074758
>>>>> UNITS METERS
>>>>> INCLUDE "../../geomoose_globals.map"
>>>>> WEB
>>>>> METADATA
>>>>> 'ows_title' 'Boulders'
>>>>> 'ows_srs' 'EPSG:3857'
>>>>> 'ows_enable_request' '*'
>>>>> 'ows_onlineresource' 'http://www.geomoose.org'
>>>>> END
>>>>> END
>>>>> PROJECTION
>>>>> 'init=EPSG:3857'
>>>>> END
>>>>> LEGEND
>>>>> STATUS ON
>>>>> LABEL
>>>>> TYPE TRUETYPE
>>>>> FONT vera_sans
>>>>> SIZE 8
>>>>> COLOR 0 0 0
>>>>> END
>>>>> END
>>>>> LAYER
>>>>> NAME "boulders"
>>>>> DATA "boulders.shp"
>>>>> STATUS DEFAULT
>>>>> TYPE POINT
>>>>> TOLERANCE 0
>>>>> LABELITEM 'BOULDER'
>>>>> LABELCACHE ON
>>>>> CLASS
>>>>> NAME 'Boulders'
>>>>> STYLE
>>>>> SYMBOL 'CIRCLE'
>>>>> COLOR 255 102 51
>>>>> OUTLINECOLOR 0 0 0
>>>>> SIZE 8
>>>>> END
>>>>> LABEL
>>>>> TYPE TRUETYPE
>>>>> FONT vera_sans-bold
>>>>> SIZE 8
>>>>> ANTIALIAS TRUE
>>>>> COLOR 0 0 0
>>>>> BUFFER 4
>>>>> PARTIALS FALSE
>>>>> POSITION auto
>>>>> SIZE 7
>>>>> END
>>>>> END
>>>>> METADATA
>>>>> END
>>>>> TOLERANCE 0
>>>>> END
>>>>> END
>>>>> Clinton Olsen
>>>>> IS/GIS Technician
>>>>> _______________________________________________
>>>>> Geomoose-users mailing list
>>>>> Geomoose-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
>>>> Dean R Anderson
>>>> IT Director
>>>> Polk County
>>> *Please note my email address has changed to clintono at emery.utah.gov.
>>> Please update your records. Thanks.
>>> Clinton Olsen
>>> *EMERY COUNTY*
>>> IS/GIS Technician
>>> 435-381-3592
>>> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
>> Dean R Anderson
>> IT Director
>> Polk County
> Clinton Olsen
> *EMERY COUNTY*
> IS/GIS Technician
> 435-381-3592
Clinton Olsen
*EMERY COUNTY*
IS/GIS Technician
435-381-3592
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140905/a34f9e46/attachment-0001.html>
More information about the Geomoose-users
