[Geomoose-users] Identify not working for non-MapServer WMS
    Paul Wickman
    paul at flatrockgeo.com
    Thu Sep 25 10:17:16 PDT 2014
Thanks, Tanya.  In this case I'm not actually using any MapServer at all,
just GeoServer WMS so there are no MapServer templates involved.
-pjw
On Thu, Sep 25, 2014 at 11:48 AM, TC Haddad <tchaddad at gmail.com> wrote:
> Hi Paul,
> Here are some things to check
> Tanya
> In your MAP file:
> - do you have requests enabled at the WEB METADATA level? e.g.:
>     WEB
>         METADATA
>             'ows_title' 'Taxlot Maps'
>             'ows_srs' ' EPSG:4326  EPSG:3857'
>             'ows_enable_request' '*'
>             'ows_onlineresource' 'http://www.yourwebsitecouldgohere.info'
>         END
>     END
> - do you have a template defined for the info tool results at the LAYER
> level? e.g.:
> LAYER
>         METADATA
>             'identify_record' 'templates/identify_parcels.html'
>         END
> END
> In your Template:
> - do you have relevant fields from your layer specified in [..] so that
> you get meaningful results returned? e.g.:
> <!--------- Mapserver template ---------->
> <table>
> <tr>
> <td align="right"><b>Owner Name:</b></td>
> <td>[OWNER]</td>
> </tr>
> <tr>
> <td align="right"><b>Situs Address:</b></td>
> <td>[SITUS]</td>
> </tr>
> </table>
> On Thu, Sep 25, 2014 at 9:31 AM, Paul Wickman <paul at flatrockgeo.com>
> wrote:
>> Hello,
>> I have some GeoServer WMS layers setup in GM v2.6.  Displays fine but am
>> not getting any results back from the Identify tool.  Looking at the
>> Javascript log I see it dispatch a call to the identify.php service but
>> nothing comes back (I have not yet poked around identify.php).
>> Here is the <map-source> definition from the mapbook.xml
>>         <map-source name="land_ownership" type="wms" opacity="0.4"
>> tiled="true" queryable="true">
>>                 <url>http://192.235.78.145/geoserver/arizona/ows</url>
>>                 <layer name="land_ownership" />
>>                 <param name="STYLES" value="land_ownership" />
>>                 <param name="FORMAT" value="image/png"/>
>>                 <param name="TRANSPARENT" value="TRUE"/>
>>         </map-source>
>> And here is the URL were you can see it in action (or rather, inaction).
>> http://192.235.78.145/geomoose/geomoose.html
>> Thanks for any advice.
>> Paul Wickman
>> CTO | Flat Rock Geographics
>> 612.280.5850 | paul at flatrockgeo.com
>> www.flatrockgeo.com | twitter.com/flatrockgeo
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
Paul Wickman
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20140925/f9aee2f5/attachment-0001.html>
More information about the Geomoose-users
