[Geomoose-users] Drawing and Markup Labeling Question/Bug?
James Klassen klassen.js at gmail.com
Fri Aug 7 08:37:22 PDT 2015
https://github.com/geomoose/geomoose/issues/101
On Fri, Aug 7, 2015 at 10:19 AM, Dan Little <theduckylittle at gmail.com>
wrote:
> Jim or Carrie, please file a ticket and I will try to get to this.
> I'm hoping to round together a 2.8.1 release and plan for the 2.9
> release.
> On Fri, Aug 7, 2015 at 10:01 AM, James Klassen <klassen.js at gmail.com>
> wrote:
> > I tried the following:
> > 1) Click create a polygon tool
> > 2) Draw a polygon
> > 3) Click the edit attributes tool
> > 4) Click on the polygon
> > 5) Make the changes in the dialog and click save
> > At this point the polygon is still selected (blue) on the map and the
> > changes don't /appear/ to have taken effect.
> > 6) Click somewhere on the map that is not on the polygon
> > Now things look as expected.
> > Thus I confirm and agree, with your assessment: the save action is not
> > clearing the selection and it would be more intuitive if it cleared the
> > selection automatically.
> > Jim
> > On Wed, Aug 5, 2015 at 4:32 PM, Carrie Quast <
> Carrie.Quast at co.brown.mn.us>
> > wrote:
> >> Hello everyone, I am playing with GeoMOOSE 2.8.0 - and so far, after a
> bit
> >> of a learning curve, it is working quite well (I've only worked with the
> >> older releases before this).
> >> My question is about the Feature Label.  After I put a drawing or markup
> >> on the map, than change the attributes (eg Color and Labels), it doesn't
> >> seem to draw with the new colors and label - it seems to stay active (it
> >> shows the blue color that indicates its being edited), even after
> saving.
> >> If I create a new drawing and markup after changing an attribute of a
> >> previous feature, the previous drawing with the changed label
> attributes is
> >> still colored blue and doesn't display label or selected color.
> >> To get the color to change and the label to appear on the map, I have to
> >> edit a drawing (any drawing on the map) or edit the label attributes of
> a
> >> different drawing (which than makes this new edited drawing stay
> selected)
> >> or click, once on the attributed point.
> >> I've tried it both my GeoMoose 2.8.0 and the live Demo (although not as
> >> extensively) and both sites do it.
> >> Is this a bug, or is this acting correctly?  I would assume that once
> the
> >> "Save Changes" button is clicked in Edit Attributes, that all actively
> >> edited points will be unactivated.
> >> I haven't checked the code behind it this, but I'm hoping its an easy
> fix.
> >> Thank You - Carrie
> >> _______________________________________________
> >> Geomoose-users mailing list
> >> Geomoose-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150807/632c78ec/attachment.html>
More information about the Geomoose-users mailing list
