[Geomoose-users] Drawing and Markup Labeling Question/Bug?
Dan Little theduckylittle at gmail.com
Fri Aug 7 08:19:12 PDT 2015
Jim or Carrie, please file a ticket and I will try to get to this.
I'm hoping to round together a 2.8.1 release and plan for the 2.9
release.
On Fri, Aug 7, 2015 at 10:01 AM, James Klassen <klassen.js at gmail.com> wrote:
> I tried the following:
> 1) Click create a polygon tool
> 2) Draw a polygon
> 3) Click the edit attributes tool
> 4) Click on the polygon
> 5) Make the changes in the dialog and click save
> At this point the polygon is still selected (blue) on the map and the
> changes don't /appear/ to have taken effect.
> 6) Click somewhere on the map that is not on the polygon
> Now things look as expected.
> Thus I confirm and agree, with your assessment: the save action is not
> clearing the selection and it would be more intuitive if it cleared the
> selection automatically.
> Jim
> On Wed, Aug 5, 2015 at 4:32 PM, Carrie Quast <Carrie.Quast at co.brown.mn.us>
> wrote:
>> Hello everyone, I am playing with GeoMOOSE 2.8.0 - and so far, after a bit
>> of a learning curve, it is working quite well (I've only worked with the
>> older releases before this).
>> My question is about the Feature Label.  After I put a drawing or markup
>> on the map, than change the attributes (eg Color and Labels), it doesn't
>> seem to draw with the new colors and label - it seems to stay active (it
>> shows the blue color that indicates its being edited), even after saving.
>> If I create a new drawing and markup after changing an attribute of a
>> previous feature, the previous drawing with the changed label attributes is
>> still colored blue and doesn't display label or selected color.
>> To get the color to change and the label to appear on the map, I have to
>> edit a drawing (any drawing on the map) or edit the label attributes of a
>> different drawing (which than makes this new edited drawing stay selected)
>> or click, once on the attributed point.
>> I've tried it both my GeoMoose 2.8.0 and the live Demo (although not as
>> extensively) and both sites do it.
>> Is this a bug, or is this acting correctly?  I would assume that once the
>> "Save Changes" button is clicked in Edit Attributes, that all actively
>> edited points will be unactivated.
>> I haven't checked the code behind it this, but I'm hoping its an easy fix.
>> Thank You - Carrie
>> Geomoose-users mailing list
>> Geomoose-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geomoose-users
More information about the Geomoose-users mailing list
