[Geomoose-users] Drawing and Markup Labeling Question/Bug?
    James Klassen
    klassen.js at gmail.com
    Fri Aug  7 08:01:14 PDT 2015
I tried the following:
1) Click create a polygon tool
2) Draw a polygon
3) Click the edit attributes tool
4) Click on the polygon
5) Make the changes in the dialog and click save
At this point the polygon is still selected (blue) on the map and the
changes don't /appear/ to have taken effect.
6) Click somewhere on the map that is not on the polygon
Now things look as expected.
Thus I confirm and agree, with your assessment: the save action is not
clearing the selection and it would be more intuitive if it cleared the
selection automatically.
Jim
On Wed, Aug 5, 2015 at 4:32 PM, Carrie Quast <Carrie.Quast at co.brown.mn.us>
wrote:
> Hello everyone, I am playing with GeoMOOSE 2.8.0 - and so far, after a bit
> of a learning curve, it is working quite well (I've only worked with the
> older releases before this).
> My question is about the Feature Label.  After I put a drawing or markup
> on the map, than change the attributes (eg Color and Labels), it doesn't
> seem to draw with the new colors and label - it seems to stay active (it
> shows the blue color that indicates its being edited), even after saving.
> If I create a new drawing and markup after changing an attribute of a
> previous feature, the previous drawing with the changed label attributes is
> still colored blue and doesn't display label or selected color.
> To get the color to change and the label to appear on the map, I have to
> edit a drawing (any drawing on the map) or edit the label attributes of a
> different drawing (which than makes this new edited drawing stay selected)
> or click, once on the attributed point.
> I've tried it both my GeoMoose 2.8.0 and the live Demo (although not as
> extensively) and both sites do it.
> Is this a bug, or is this acting correctly?  I would assume that once the
> "Save Changes" button is clicked in Edit Attributes, that all actively
> edited points will be unactivated.
> I haven't checked the code behind it this, but I'm hoping its an easy fix.
> Thank You - Carrie
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150807/da96b631/attachment.html>
More information about the Geomoose-users
