[Geomoose-users] compatibility issues with Microsoft Edge
Brent Fraser bfraser at geoanalytic.com
Wed Aug 26 09:24:58 PDT 2015
Mark,
   I've done some simple tests with edge and GeoMoose v2.8 and it works
well.  Microsoft's doc on Windows 10's Edge says they've dropped
backwards compatibility of their previous browsers to improve
performance, so I doubt there will be a setting.  I did an upgrade from
Windows 7 but I believe they are still delivering Internet Explorer as
well as Edge with Windows 10 so potentially the work around is "Use
Internet Explorer" (at least until the customer moves to GM 2.8).
Best Regards,
Brent Fraser
On 8/26/2015 9:31 AM, James Klassen wrote:
> GeoMoose 2.2 is a relic from a bygone era of horrendously broken web
> browsers with non standard Javascript engines and broken DOMs.  We had
> to do things to work around the chaos of the time.  Some of those were
> not so good things, the kind of things you don't talk about in
> pleasant company, others were just stupid mistakes.
> The good news is browsers have gotten better and we have worked
> tirelessly since then to overcome those past scars to make GeoMoose
> better, faster, more reliable, and more widely compatible.  The result
> of those efforts is currently GeoMoose 2.8, which I just checked
> appears to work with MS Edge.
> There may be some hack to get it working, but I honestly believe the
> best way to make GeoMoose 2.2 work with Edge is to upgrade to GeoMoose
> 2.8.
> Jim
> On Aug 26, 2015 09:48, "Mark Volz" <MarkVolz at co.lyon.mn.us
> <mailto:MarkVolz at co.lyon.mn.us>> wrote:
>     Hello,
>     I had a customer mention that GeoMOOSE 2.2 does not work with
>     Microsoft Edge.  We had a meta tag that we used to force newer
>     versions of IE to work in compatibility mode.  Is there any
>     equivalent meta tag in Microsoft Edge?  Does this problem impact
>     newer versions of GeoMOOSE?
>     Thanks
>     Code I used to get GeoMOOSE 2.2 to work in IE
>       <head>
>       <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE8" />
>       <title>My GeoMOOSE Site</title>
>     Thanks
>     Sincerely,
>     *Mark Volz*
>     _______________________________________________
>     Geomoose-users mailing list
>     Geomoose-users at lists.osgeo.org <mailto:Geomoose-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150826/c26d9da5/attachment.html>
More information about the Geomoose-users mailing list
