[Geomoose-users] Change projection
Mark Volz
MarkVolz at co.lyon.mn.us
Mon Jan 5 11:33:13 PST 2015
Geograefin,
· Check your projection in settings.ini *I personally don’t know if the projection in local_settings.ini will override the projection in settings.ini, however it might be worth a shot to change this.
· Did you create a projection file such as …\apps\geomoose2\htdocs\projections\EPSG25833.js
· Is the map displaying in the correct area, or is it still somewhere over North America?
Sincerely,
Mark Volz, GISP
Lyon County GIS Coordinator
From: geomoose-users-bounces at lists.osgeo.org [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of Mark Volz
Sent: Monday, January 05, 2015 12:00 PM
To: geo.graefin at web.de; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Change projection
Geograefin,
Is your site publicly accessible yet? Or could you send me a copy of settings.ini and mapbook.xml?
Sincerely,
Mark Volz, GISP
From: geomoose-users-bounces at lists.osgeo.org<mailto:geomoose-users-bounces at lists.osgeo.org> [mailto:geomoose-users-bounces at lists.osgeo.org] On Behalf Of geo.graefin at web.de<mailto:geo.graefin at web.de>
Sent: Monday, January 05, 2015 10:35 AM
To: geomoose-users at lists.osgeo.org<mailto:geomoose-users at lists.osgeo.org>
Subject: [Geomoose-users] Change projection
Dear community,
I have problems with changing the projection of my GeoMOOSE project. I have followed the instructions at the GeoMOOSE site [http://docs.geomoose.org/2.7/docs/projections.html]. In addition to all these steps I changed the EPSG code in local_settings.ini. But there is no effect. It still shows the projection (EPSG code 26915) of the demo, as well as the coordinates x,y at the status bar. The "new" epsg code is 25833.
Do you have any ideas, what instructions are missing or what i did wrong?
I would be very grateful for help! Thank you in advance!
Greetings, Geograefin
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150105/8db6009f/attachment-0001.html>
More information about the Geomoose-users
