[Geomoose-users] Adding every layer from an ArcGIS WMS Server?
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Fri May 15 11:15:02 PDT 2015
Hi Mark,
You would probably not be able to get away from needing to define  all the layers you want, but having said that, you should be able to pass the many layered WMS through Mapserver (as a client) and then pass off a new composite layer with Mapserver (as a service).
there might be an option available using a REGEX inside a SLD request.
bobb
On May 15, 2015, at 11:49 AM, Mark Volz <MarkVolz at co.lyon.mn.us<mailto:MarkVolz at co.lyon.mn.us>> wrote:
Hello,
I created a WMS server using ArcGIS.  The map that I published includes 201 historic images of our county.  By default ArcGIS lists each image separately such as layer 1, layer 2, layer 3 etc.  I would like to add the WMS service to GeoMOOSE but I want to avoid listing each layer separately.
Is there a way to pull in all the layers from a WMS source so I don’t have to list off 201 layers?
                <map-source name="AirPhotos1938" type="wms" reference="false" projection='EPSG:103749' tiled="true" width='256' height='256' transition_Effect="resize">
                                <url>http://gis.lyonco.org/arcgis/services/LyonBasemaps/1938AirPhotos/MapServer/WMSServer?</url><http://gis.lyonco.org/arcgis/services/LyonBasemaps/1938AirPhotos/MapServer/WMSServer?%3C/url%3E>
                                                <layer name="1"/>
                                                <layer name="2"/>
                                                <layer name="3"/>
                                                <layer name="201"/>
                                                <param name="STYLES" value=""/>
                </map-source>
Thank You!
Mark Volz
Lyon County GIS
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org<mailto:Geomoose-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150515/28a8a093/attachment-0001.html>
More information about the Geomoose-users mailing list
