[Geomoose-users] Feature Report error with Identify Tool
Brent Fraser
bfraser at geoanalytic.com
Wed May 27 06:36:02 PDT 2015
Fernando,
Your EXTENT is set to
EXTENT -136 -1 227 362
UNITS METERS
while not technically invalid, it means you are mapping an area about
400 meters by 400 meters off the coast of Africa. Try setting the
EXTENT to values for your mapping area.
Best Regards,
Brent Fraser
On 5/27/2015 3:44 AM, Fernando wrote:
> Hello again, after making the "Identify" tool to work properly, I
> added the option "feature_report" but fails.
> My identify.html file is:
> <! - MapServer Template ->
> <Tr bgcolor = "# DEE5EB"> <td colspan = "2"> <b> <u> SPACE </ u> </ b>
> </ tr>
> <Tr>
> <Td align = "right"> <b> IDENTIFIER: </ b> </ td>
> <Td> [dxf_text] <a
> href="javascript:GeoMOOSE.startService('feature_report',
> {'dxf_text':'[dxf_text]','src':'edificio_c2_espacios/C2-ALBERT_EINSTEIN'})">
> Report </ a> </ td>
> </ Tr>
> <Tr>
> <Td align = "right"> <b> Content: </ b> </ td>
> <Td> [content] </ td>
> </ Tr>
> My map file is:
> MAP
> NAME EDIFICIO_C2_MAP
> STATUS ON
> SIZE 800 800
> UNITS METERS
> INCLUDE "./geomoose_globals.map"
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> SYMBOLSET "./symbols/symbol.sym"
> FONTSET "./fonts/fontset.list"
> TRANSPARENT FALSE
> RESOLUTION 100
> DEFRESOLUTION 100
> CONFIG "MS_ERRORFILE" "/ms4w/ms_error_c2.txt"
> DEBUG 5
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> FORMATOPTION "GAMMA=0.75"
> END
> My parcel.xml file is:
> <feature-report>
> <!-- query informtion -->
> <query item="dxf_text" string="%qstring%"/>
> <!-- This is the template -->
> <template>parcel_template.pdf</template>
> <!-- this is the location of the map in the template -->
> <map x="0.92" y="2.18" w="6.69" h="3.68"/>
> <!-- This is a list of where the fields are to be printed on the
> template -->
> <fields>
> <field x=".5" y="7.25" src="%dxf_text%" title="IDENTIFICADOR:"/>
> <field x=".5" y="7.45" src="%contenido%" title="CONTENIDO:"/>
> <field x=".5" y="8.25" src="%area%" title="AREA:" format='%0.2f'/>
> <field x=".5" y="8.45" src="%perimeter%" title="PERIMETRO:"/>
> </fields>
> </feature-report>
> Test search results:
> Detailed information for the area you clicked on the map ...
> Ground Coordinates
> X: 116.27685546875
> Y: 299.78662109375
> SPACES
> IDENTIFIER: 16C2BN001 Report
> CONTENTS: DEPARTMENT HALL. PHYSICAL
> LOCATION TYPE: HALL
> USE TYPE: COMMON AREA
> Error when I click on the hyperlink "Report":
> Warning: layerObj :: queryByRect (): [MapServer Error]:
> msPostGISLayerWhichShapes (): Error executing query: ERROR: syntax
> error at or near "C2BN001"
> LINE 1: ... -1 362.227 362.227 -136 -1 -136 -1)) ', 3857) and (16C2BN001)
> in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php on
> line 72
> Warning: MapObj :: SetExtent (): [MapServer Error]: SetExtent ():
> Given extent map is invalid. Check That it is in the form: minx, miny,
> maxx, maxy
> line 100
> line 100
> Fatal error: Uncaught exception 'MapScriptException' in C: \ MS4W \
> apps \ geomoose2 \ htdocs \ php \ feature_report.php: 100
> Stack trace:
> # 0 C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php
> (100) mapObj-> SetExtent (0, 0, 0, 0)
> # 1 {main}
> thrown in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \
> feature_report.php on line 100
> Can anyone help me fix the error?
> Geomoose-users mailing list
> Geomoose-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150527/75790376/attachment-0001.html>
More information about the Geomoose-users
