[Geomoose-users] Feature Report error with Identify Tool
    Fernando
    nando_gcia at hotmail.com
    Thu May 28 03:10:36 PDT 2015
Brent, thank you for your replies but how can I georeference the building plan correctly ? Actually we don't need to have an real coordinate system, that does not matter in the project. We start from a DXF AutoCAD drawing and converted into shapefile with ArcTools and then import it to POSTGIS. To display online we decided to try GeoMOOSE.
How do you think that would solve the error?
Date: Wed, 27 May 2015 07:36:02 -0600
To: nando_gcia at hotmail.com; geomoose-users at lists.osgeo.org
Subject: Re: [Geomoose-users] Feature Report error with Identify Tool
    Fernando,
      Your EXTENT is set to
           EXTENT -136 -1 227 362
           UNITS METERS
        while not technically invalid, it means you are mapping an area
        about 400 meters by 400 meters off the coast of Africa.  Try
        setting the EXTENT to values for your mapping area.
    Best Regards,
Brent Fraser
    On 5/27/2015 3:44 AM, Fernando wrote:
      Hello again, after making the "Identify" tool to work
            properly, I added the option "feature_report" but fails.
          My identify.html file is:
          <! - MapServer Template ->
          <Tr
            bgcolor = "# DEE5EB"> <td colspan = "2"> <b>
            <u> SPACE </ u> </ b> </ tr>
          <Tr>
          <Td align = "right"> <b> IDENTIFIER: </
            b> </ td>
          <Td>
            [dxf_text] <a
            href="javascript:GeoMOOSE.startService('feature_report',
            {'dxf_text':'[dxf_text]','src':'edificio_c2_espacios/C2-ALBERT_EINSTEIN'})">
            Report </ a> </ td>
          </ Tr>
          <Tr>
          <Td align = "right"> <b> Content: </ b>
            </ td>
          <Td> [content] </ td>
          </ Tr>
            My map file is:
            MAP
                NAME EDIFICIO_C2_MAP
                STATUS ON
                SIZE 800 800
                UNITS METERS
                INCLUDE "./geomoose_globals.map"
                IMAGECOLOR 255 255 255
                IMAGETYPE PNG
                SYMBOLSET "./symbols/symbol.sym"
                FONTSET "./fonts/fontset.list"
                TRANSPARENT FALSE
                RESOLUTION 100
                DEFRESOLUTION 100
                CONFIG "MS_ERRORFILE" "/ms4w/ms_error_c2.txt"
                DEBUG 5
              OUTPUTFORMAT
              NAME png
              DRIVER "AGG/PNG"
              MIMETYPE "image/png"
              IMAGEMODE PC256
              EXTENSION "png"
              FORMATOPTION "GAMMA=0.75"
            END
        My parcel.xml file is:
              <feature-report>
                <!-- query informtion -->
                <query item="dxf_text" string="%qstring%"/>
                <!-- This is the template -->
                <template>parcel_template.pdf</template>
                <!-- this is the location of the map in the template
                <map x="0.92" y="2.18" w="6.69" h="3.68"/>
                <!-- This is a list of where the fields are to be
            printed on the template -->
                <fields>
                    <field x=".5" y="7.25" src="%dxf_text%"
            title="IDENTIFICADOR:"/>
                    <field x=".5" y="7.45" src="%contenido%"
            title="CONTENIDO:"/>
                    <field x=".5" y="8.25" src="%area%" title="AREA:"
            format='%0.2f'/>
                    <field x=".5" y="8.45" src="%perimeter%"
            title="PERIMETRO:"/>
                </fields>
            </feature-report>
          Test search results:
          Detailed information for the area you clicked on the map
          Ground Coordinates
          X: 116.27685546875
          Y: 299.78662109375
          SPACES
          IDENTIFIER: 16C2BN001   Report
          CONTENTS:
            DEPARTMENT HALL. PHYSICAL
          LOCATION TYPE: HALL
          USE TYPE: COMMON AREA
          Error when I click on the hyperlink "Report":
              Warning: layerObj :: queryByRect (): [MapServer Error]:
            msPostGISLayerWhichShapes (): Error executing query: ERROR:
            syntax error at or near "C2BN001"
          LINE 1:
            ... -1 362.227 362.227 -136 -1 -136 -1)) ', 3857) and
            (16C2BN001)
              in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \
            feature_report.php on line 72
          Warning:
            MapObj :: SetExtent (): [MapServer Error]: SetExtent ():
            Given extent map is invalid. Check That it is in the form: minx, miny, maxx, maxy
            feature_report.php on line 100
          Warning: MapObj :: SetExtent (): [MapServer Error]:
          LINE 1:
            (16C2BN001)
          Fatal error: Uncaught exception 'MapScriptException' in C:
            feature_report.php: 100
          Stack trace:
          # 0 C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \
            feature_report.php (100) mapObj-> SetExtent (0, 0, 0, 0)
          # 1 {main}
              thrown in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \
            Can anyone help me fix the error?
Geomoose-users mailing list
Geomoose-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150528/a947b7e6/attachment.html>
More information about the Geomoose-users
