[Geomoose-users] Feature Report error with Identify Tool
TC Haddad
tchaddad at gmail.com
Thu May 28 07:50:17 PDT 2015
Hi Fernando,
The errors say that when trying to query by your rectangle, the given
extent is invalid (for the stated projection).
Warning: layerObj :: queryByRect (): [MapServer Error]:
msPostGISLayerWhichShapes (): Error executing query: ERROR: syntax error at
or near "C2BN001"
LINE 1: ... -1 362.227 362.227 -136 -1 -136 -1)) ', 3857) and (16C2BN001)
It actually looks like too many extent parameters are being passed (more
than 4). I'm not sure why this might happen, but perhaps that's a clue you
can investigate?
Tanya
On Thu, May 28, 2015 at 3:10 AM, Fernando <nando_gcia at hotmail.com> wrote:
> Brent, thank you for your replies but how can I georeference the building
> plan correctly ? Actually we don't need to have an real coordinate system, that
> does not matter in the project. We start from a DXF AutoCAD drawing and converted
> into shapefile with ArcTools and then import it to POSTGIS. To display
> online we decided to try GeoMOOSE.
> How do you think that would solve the error?
> Date: Wed, 27 May 2015 07:36:02 -0600
> From: bfraser at geoanalytic.com
> To: nando_gcia at hotmail.com; geomoose-users at lists.osgeo.org
> Subject: Re: [Geomoose-users] Feature Report error with Identify Tool
> Fernando,
> Your EXTENT is set to
> EXTENT -136 -1 227 362
> UNITS METERS
> while not technically invalid, it means you are mapping an area about 400
> meters by 400 meters off the coast of Africa. Try setting the EXTENT to
> values for your mapping area.
> Best Regards,
> Brent Fraser
> On 5/27/2015 3:44 AM, Fernando wrote:
> Hello again, after making the "Identify" tool to work properly, I added
> the option "feature_report" but fails.
> My identify.html file is:
> <! - MapServer Template ->
> <Tr bgcolor = "# DEE5EB"> <td colspan = "2"> <b> <u> SPACE </ u> </ b> </
> tr>
> <Tr>
> <Td align = "right"> <b> IDENTIFIER: </ b> </ td>
> <Td> [dxf_text] <a href="javascript:GeoMOOSE.startService('feature_report',
> {'dxf_text':'[dxf_text]','src':'edificio_c2_espacios/C2-ALBERT_EINSTEIN'})">
> Report </ a> </ td>
> </ Tr>
> <Tr>
> <Td align = "right"> <b> Content: </ b> </ td>
> <Td> [content] </ td>
> </ Tr>
> My map file is:
> MAP
> NAME EDIFICIO_C2_MAP
> STATUS ON
> SIZE 800 800
> UNITS METERS
> INCLUDE "./geomoose_globals.map"
> IMAGECOLOR 255 255 255
> IMAGETYPE PNG
> SYMBOLSET "./symbols/symbol.sym"
> FONTSET "./fonts/fontset.list"
> TRANSPARENT FALSE
> RESOLUTION 100
> DEFRESOLUTION 100
> CONFIG "MS_ERRORFILE" "/ms4w/ms_error_c2.txt"
> DEBUG 5
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE "image/png"
> IMAGEMODE PC256
> EXTENSION "png"
> FORMATOPTION "GAMMA=0.75"
> END
> My parcel.xml file is:
> <feature-report>
> <!-- query informtion -->
> <query item="dxf_text" string="%qstring%"/>
> <!-- This is the template -->
> <template>parcel_template.pdf</template>
> <!-- this is the location of the map in the template -->
> <map x="0.92" y="2.18" w="6.69" h="3.68"/>
> <!-- This is a list of where the fields are to be printed on the
> template -->
> <fields>
> <field x=".5" y="7.25" src="%dxf_text%" title="IDENTIFICADOR:"/>
> <field x=".5" y="7.45" src="%contenido%" title="CONTENIDO:"/>
> <field x=".5" y="8.25" src="%area%" title="AREA:" format='%0.2f'/>
> <field x=".5" y="8.45" src="%perimeter%" title="PERIMETRO:"/>
> </fields>
> </feature-report>
> Test search results:
> Detailed information for the area you clicked on the map ...
> Ground Coordinates
> X: 116.27685546875
> Y: 299.78662109375
> SPACES
> IDENTIFIER: 16C2BN001 Report
> CONTENTS: DEPARTMENT HALL. PHYSICAL
> LOCATION TYPE: HALL
> USE TYPE: COMMON AREA
> Error when I click on the hyperlink "Report":
> or near "C2BN001"
> in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php on
> line 72
> Warning: MapObj :: SetExtent (): [MapServer Error]: SetExtent (): Given
> extent map is invalid. Check That it is in the form: minx, miny, maxx,
> maxy
> line 100
> or near "C2BN001"
> line 100
> Fatal error: Uncaught exception 'MapScriptException' in C: \ MS4W \ apps \
> geomoose2 \ htdocs \ php \ feature_report.php: 100
> Stack trace:
> # 0 C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \ feature_report.php (100)
> mapObj-> SetExtent (0, 0, 0, 0)
> # 1 {main}
> thrown in C: \ MS4W \ apps \ geomoose2 \ htdocs \ php \
> feature_report.php on line 100
> Can anyone help me fix the error?
> Geomoose-users mailing listGeomoose-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/geomoose-users
URL: <http://lists.osgeo.org/pipermail/geomoose-users/attachments/20150528/dede2200/attachment-0001.html>
More information about the Geomoose-users
